tokhee Posted December 30, 2020 Share #1 Posted December 30, 2020 Advertisement (gone after registration) hello. just got my first Leica, a used Q, and loving it! when shooting, I like to press my eye against the eyecup on the EVF. But because the way it is built on the Q, when I do this, it leaves a smudge on the EVF. Does anyone know if there is some sort of eyecup extender? thank you. Link to post Share on other sites More sharing options...
Advertisement Posted December 30, 2020 Posted December 30, 2020 Hi tokhee, Take a look here Eyecup?. I'm sure you'll find what you were looking for!
nwphil Posted December 30, 2020 Share #2 Posted December 30, 2020 Congratulations on the new (to you) camera I don't think so, and truly the Qs were not designed to have such - per concept and ergonomics. It seems that is more of handling technique issue - don't know what type of camera you have been using, but you just need to adapt. One solution could be to make your own - likely to require a 3D printer and the use of silicone molding making rubber/compound - something like this: https://www.amazon.com/dp/B004BNF3TK/?coliid=I2LYW0UWWQ99Y6&colid=J52MJ1CQCY39&psc=1&ref_=lv_ov_lig_dp_it imo, I don't think the effort and expense is worth the trouble Link to post Share on other sites More sharing options...
tokhee Posted December 30, 2020 Author Share #3 Posted December 30, 2020 thank you @nwphil. appreciate your reply. my previous cameras were the 5D mark 2, and the Fuji X-T2, 3 and XH-1. I like to put my eye against the EVF and "isolate" from my surroundings when I shoot. I also feel more balanced/stable when there is one more point of contact with the camera. Link to post Share on other sites More sharing options...
nwphil Posted December 30, 2020 Share #4 Posted December 30, 2020 yeah, for the looks of it, the Q2M has a very similar evf shape, and also shallow. I usually wear a baseball cap outside, so it becomes helpful at times, as can be slightly adjusted to cover the left or right side a bit. Not a perfect solution , I know.... Link to post Share on other sites More sharing options...
