Telemetric Posted December 30, 2020 Share #1 Posted December 30, 2020 Advertisement (gone after registration) Hello, Recently I updated my Q2 to the 3.0 firmware version. I had the right top button configured for the ISO and the right wheel to choose which ISO to use and now it changed. The problem is I can't find where to configure it again as it was before. I will appreciate any suggestion. Thanks a lot in advance. Link to post Share on other sites More sharing options...
Advertisement Posted December 30, 2020 Posted December 30, 2020 Hi Telemetric, Take a look here Q2 ISO and right wheel . I'm sure you'll find what you were looking for!
nwphil Posted December 30, 2020 Share #2 Posted December 30, 2020 no sure if the Q2M has the exact same UI ( for sure no color controls) - if you hold the right top wheel button for 2 seconds, it will open the other available to use settings assigned to this button - use keypad to select and confirm; once you tap top right button again the new selection will be active. To assigned settings to a specific button you have to use MENU, CUSTOMIZE CONTROL, RIGHT WHEEL BUTTON and then activate up to 8 menu items (check or uncheck as needed) 1 Link to post Share on other sites More sharing options...
Telemetric Posted December 30, 2020 Author Share #3 Posted December 30, 2020 I will try! Thanks a lot! Link to post Share on other sites More sharing options...
Telemetric Posted January 16, 2021 Author Share #4 Posted January 16, 2021 Well, problem solved. I reinstalled the older version and, after, I updated to the last one again and... it worked as before... Thanks for your answers anyway, Link to post Share on other sites More sharing options...
