You can use the Split Tone panel, which is now referred to as Color Grading in the most recent LR Classic. This works on Monochrom files. You can separately adjust shadows and highlights (and now mid-tones, too) for both hue and saturation, and further adjust balance and blending.  You might start by bumping shadow hue to 40-ish and saturation to 50-ish. Depends on the look you’re after, but you’ll get the idea with some experimentation.
Jeff
50 minutes ago, plantagoo said:
You may try to play around with the color curves to achieve toning in LR mobile.
Greetings
Erik
Color channels (rgb) don’t apply within the tone curve with a Monochrom, which has no sensor color array.  But I don’t use LR mobile, so if this refers to a toning application, that’s another matter.
Jeff
