danmdan Posted November 6, 2020 Share #1 Posted November 6, 2020 Advertisement (gone after registration) I have a model T fitted with an 18-56mm Vario-Elmar-T zoom. I usually have the camera set on bursts of 3 shots for the -1,0,+1 ev exposures. So when I do take any shot the top red light on the body, (which I assume signifies writing to the SD card) stays on for a short period while the data is written to the SD card. Now if I alter the zoom setting while that red indicator is lit, the red light stays on and the camera freezes-up and will not allow any more shots to be taken. While this does not happen every time, it happens often enough to be a real annoyance. So I then have to turn the power off and on again, to resume picture taking. My thoughts are that moving the zoom ring sends data to the body, and if this is done while the body is writing to the SD card, the conflict causes a program crash. Any idea if this indeed is the problem and cause ? Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2020 Posted November 6, 2020 Hi danmdan, Take a look here Unusual T (typ701) problem.. I'm sure you'll find what you were looking for!
M.piras Posted November 8, 2020 Share #2 Posted November 8, 2020 I suppose more probably, moving zoom make fail the light exposure causing a freeze. If you do same without bracketing option it works properly? Have you tried to press menu button when it happens? Try if happens also with the flash Link to post Share on other sites More sharing options...
danmdan Posted December 6, 2020 Author Share #3 Posted December 6, 2020 (edited) @M.piras - No, it happens after all three exposures are taken, during when the SD card is being written to, as indicated by the red light being on/lit. Edited December 6, 2020 by danmdan Link to post Share on other sites More sharing options...
