Flight959 Posted November 4, 2020 Share #1 Posted November 4, 2020 (edited) Advertisement (gone after registration) Hi, Hope everyone is keeping safe. I went out this afternoon with my Monochrom MK1. I had a go at shooting some long exposures. I noticed this evening whilst processing my photos several clusters whilst zoomed in of these dots. initially I thought it was dust. They have a dark center then a circular lighter area then a lighter halo.... is this corrosion. Apologies...its a photo taken of my laptop screen... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! IMG_20201104_190555 by Simon Clarkson, on Flickr After buying the camera (no reason other than piece of mind) I contacted Leica with the serial number to enquire if the sensor had been replaced. Jimmy at Leica Mayfair confirmed that in July 2017 the camera had a replacement Sensor with the later cover glass which was not subject to delamination. Do I have an issue?? Or is this moisture dots or dust.. I was shooting at F22 so its the first time ive seen it. Regards Simon Flight959 Edited November 4, 2020 by Flight959 inncorect description Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! IMG_20201104_190555 by Simon Clarkson, on Flickr After buying the camera (no reason other than piece of mind) I contacted Leica with the serial number to enquire if the sensor had been replaced. Jimmy at Leica Mayfair confirmed that in July 2017 the camera had a replacement Sensor with the later cover glass which was not subject to delamination. Do I have an issue?? Or is this moisture dots or dust.. I was shooting at F22 so its the first time ive seen it. Regards Simon Flight959 ' data-webShareUrl='https://www.l-camera-forum.com/topic/314809-corrosion/?do=findComment&comment=4074103'>More sharing options...
Advertisement Posted November 4, 2020 Posted November 4, 2020 Hi Flight959, Take a look here Corrosion?. I'm sure you'll find what you were looking for!
BrianS Posted November 4, 2020 Share #2 Posted November 4, 2020 You are at 400% magnification. This is more likely Dust. Try cleaning the sensor, use a blower, or wet clean. The corrosion spots on my sensor were big enough to be seen using the LCD screen on the camera alone. I had it replaced under warranty several years ago, with the new sensor. Link to post Share on other sites More sharing options...
digger1914 Posted November 5, 2020 Share #3 Posted November 5, 2020 As an example, this is how my M9 looked when it got corrosion and was replaced Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/314809-corrosion/?do=findComment&comment=4074162'>More sharing options...
Chuck Albertson Posted November 5, 2020 Share #4 Posted November 5, 2020 5 hours ago, Flight959 said: Hi, Hope everyone is keeping safe. I went out this afternoon with my Monochrom MK1. I had a go at shooting some long exposures. I noticed this evening whilst processing my photos several clusters whilst zoomed in of these dots. initially I thought it was dust. They have a dark center then a circular lighter area then a lighter halo.... is this corrosion. Apologies...its a photo taken of my laptop screen... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! IMG_20201104_190555 by Simon Clarkson, on Flickr After buying the camera (no reason other than piece of mind) I contacted Leica with the serial number to enquire if the sensor had been replaced. Jimmy at Leica Mayfair confirmed that in July 2017 the camera had a replacement Sensor with the later cover glass which was not subject to delamination. Do I have an issue?? Or is this moisture dots or dust.. I was shooting at F22 so its the first time ive seen it. Regards Simon Flight959 It may just be a dirty sensor. I had a similar spot develop on the sensor of my MM about a year after the original sensor corroded and was replaced with the new version. I thought it was corrosion in the new sensor (which would have been very disappointing), and sent it in to Leica NJ. They determined that it was just a dirty sensor, cleaned it and returned it to me. Link to post Share on other sites More sharing options...
michali Posted November 5, 2020 Share #5 Posted November 5, 2020 (edited) 9 hours ago, Flight959 said: Hi, Hope everyone is keeping safe. I went out this afternoon with my Monochrom MK1. I had a go at shooting some long exposures. I noticed this evening whilst processing my photos several clusters whilst zoomed in of these dots. initially I thought it was dust. They have a dark center then a circular lighter area then a lighter halo.... is this corrosion. Apologies...its a photo taken of my laptop screen... IMG_20201104_190555 by Simon Clarkson, on Flickr After buying the camera (no reason other than piece of mind) I contacted Leica with the serial number to enquire if the sensor had been replaced. Jimmy at Leica Mayfair confirmed that in July 2017 the camera had a replacement Sensor with the later cover glass which was not subject to delamination. Do I have an issue?? Or is this moisture dots or dust.. I was shooting at F22 so its the first time ive seen it. Regards Simon Flight959 Simon- Difficult to tell from the image you've posted, it's easier to determine at 100% magnification. However I really doubt that it's corrosion, there have been no reported events with the vers.2 cover glass. I've had sensor corrosion on both my M9 & Monochrom, twice with each camera. Leica replaced the the cover glass with vers.1 both times on both cameras and the sensors corroded again. This was in mid-2015, the vers.2 cover glass was introduced in about Oct. 2015. This is what my Monchrom sensor looked like @ 100% -The yellow circles are dust and the red corrosion. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 5, 2020 by michali Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/314809-corrosion/?do=findComment&comment=4074230'>More sharing options...
Flight959 Posted November 5, 2020 Author Share #6 Posted November 5, 2020 Thanks for the replies. The sensor was last cleaned earlier this year by Leica. I'll ask them to clean and check for me. Regards Simon. Link to post Share on other sites More sharing options...
