digger1914 Posted June 9, 2020 Share #21 Posted June 9, 2020 Advertisement (gone after registration) On 6/6/2020 at 1:50 AM, tom.w.bn said: No one said, that it does not work together 🙂 But C1 + SEP is not non-destructive. When you work on an image in C1 and then go to SEP, the result is baked in a TIF File. You can only apply more changes to the TIF File but you can't revert changes you did before. When I understand it right then with LR + SEP 3 you can undo changes later. I can confirm that C1 uses the new "Save & Edit Later" option. You start with "Edit With" for the original changes, and if you use "Open With" subsequently, all your adjustments are there to be played with. 1 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 9, 2020 Posted June 9, 2020 Hi digger1914, Take a look here Upgrade to Nik Collection 3? . I'm sure you'll find what you were looking for!
