Schittra Posted May 26, 2020 Share #1  Posted May 26, 2020 Advertisement (gone after registration) I bought the "Voigtlander Heiliar 12mm/5.6" at quite cheap in local shop. First time for me to go at this wide. Because this is super wide angle, I don't see much change when I varied the stop or even focusing distance. Here are my experimentation this morning. Is this what I should expect from the lens or this lens is damage (not proper focusing)? When I varied the f/stop, the blades move and shutter varied though. First experience - f/stop variation. All shots taken by Leica SL, setting ISO50000 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/309980-voigtlander-heiliar-12mm56/?do=findComment&comment=3980647'>More sharing options...
Advertisement Posted May 26, 2020 Posted May 26, 2020 Hi Schittra, Take a look here Voigtlander Heiliar 12mm/5.6. I'm sure you'll find what you were looking for!
Schittra Posted May 26, 2020 Author Share #2  Posted May 26, 2020 Second experiments - fix f/ Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! stop at 5.6 and vary focusing distance. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! stop at 5.6 and vary focusing distance. ' data-webShareUrl='https://www.l-camera-forum.com/topic/309980-voigtlander-heiliar-12mm56/?do=findComment&comment=3980648'>More sharing options...
james.liam Posted May 26, 2020 Share #3 Â Posted May 26, 2020 Which of the 3 versions is it? Link to post Share on other sites More sharing options...
Schittra Posted May 26, 2020 Author Share #4 Â Posted May 26, 2020 2 hours ago, james.liam said: Which of the 3 versions is it? The version 3 Link to post Share on other sites More sharing options...
Tailwagger Posted May 26, 2020 Share #5  Posted May 26, 2020 Maybe I'm missing something here, but if you're trying to discern differences in image quality when varying focus and f-stop, why would you ever do it by shooting at 50000? All that does is introduce enough noise that neither matters much anyway. Link to post Share on other sites More sharing options...
01af Posted May 26, 2020 Share #6 Â Posted May 26, 2020 vor 7 Stunden schrieb Schittra: Is this what I should expect from the lens ...? [...] Yes. 1 Link to post Share on other sites More sharing options...
Schittra Posted May 26, 2020 Author Share #7  Posted May 26, 2020 Advertisement (gone after registration) 40 minutes ago, Tailwagger said: Maybe I'm missing something here, but if you're trying to discern differences in image quality when varying focus and f-stop, why would you ever do it by shooting at 50000? All that does is introduce enough noise that neither matters much anyway. Thanks. I tried this morning and not enough light. Too lazy to take tripod. This is the second set with ISO 1600. any idea? Link to post Share on other sites More sharing options...
Schittra Posted May 26, 2020 Author Share #8  Posted May 26, 2020 Same place with ISO 1600 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/309980-voigtlander-heiliar-12mm56/?do=findComment&comment=3980739'>More sharing options...
Schittra Posted May 26, 2020 Author Share #9  Posted May 26, 2020 Now with iso1600, set f/5.6 and vary focusing ring  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/309980-voigtlander-heiliar-12mm56/?do=findComment&comment=3980745'>More sharing options...
Tailwagger Posted May 26, 2020 Share #10  Posted May 26, 2020 4 hours ago, Schittra said: Thanks. I tried this morning and not enough light. Too lazy to take tripod. This is the second set with ISO 1600. any idea? But I've woken up now, had some coffee, thinking a bit more clearly yet I'm still confused. I'll start by saying that I don't own this lens, but a 12mm, not seeing a lot of change is unsurprising to me.  First, if should be obvious if the aperture is changing simply by looking down the barrel of the lens and seeing if the iris stops up or down when you rotate the ring. It's hard to spot any differences, even at 1600, but it appears to me that theres a bit more CA at f22 which should be expected, so my guess is that it is working. Typically if a mechanical aperture ring isnt working it seized or spins freely. As for focusing, again, lens off camera, if you look at the rear of the mount, you should see things move. No guarantee your lens is properly calibrated, but for this optic, who cares? Everything is pretty much always going to be in focus regardless of your settings.  So returning to your original question, "Is this what I should expect from the lens?".  I ran the numbers via PhotoPills (a worthwhile app if you don't own it) and a 12mm lens on an SL at f5.6 focused to 1m has a DoF near limit of 0.46m and far limit of infinity. ie. everything is in focus. Essentially, with this lens, if you set the aperture to f8 and glued the focus to 2M, everything from half a meter to infinity should be in focus. Given that, assuming everything is rotating freely, I think what you're seeing is to be expected. 2 Link to post Share on other sites More sharing options...
