LC-1 manual white balance
jtharvie
I am ready to attempt setting the white balance manually but I am a bit confused . . . I have a 4in x 5in Kodak 18% gray card . . . one side is gray and the other is white. Can I use the gray side? If I fill the frame with the gray side using the zoom then follow the instruction of setting white balance will I get the same results as using the white side?
Robin,
Yes I read that and I read several different sources on the internet. Seems to me either will give good results and as I am shooting RAW, I can adjust in PhotoShop. I am going to try both and see what I get. Thanks for your response.
Cheers,
JTH
For setting white balance, any neutral (gray/white) surface will do. Either the gray or the white side of a gray card.
But avoid superwhites - like white car paint or freshly-laundered white cloth - that have brighteners or 'bluing' to make them look extra-white. They reflect unnatural amounts of UV and can lead to too yellow a white balance.
