Card Reader Problem
Guest Essemmlee
Guest Essemmlee
Can anybody help.
It was working, now it isn't. I can get the pix off the camera by direct USB connection but the reader seems to have ground to a halt. I've heard it might be a software clash - does anyone have a similar experience?
I have problems with my reader from time to time, a SanDisk Imagemate SD reader. I buy the SanDisk Ultra II cards with a built-in USB plug, so when things go south, I still have another way. I am planning to replace the reader with something more stable. Funny, that was what I thought I was getting when I bought the SanDisk reader, since the cards have been solid...
I have an issue of variable speeds on downloading from card reader and camera. Seems to be about 10BM/30sec. However if I download immeadiately on start up the download speed is 10MB/1 sec. I'm running OS X 10.4.10 on intel mac and have reinstalled from 10.4.6 to try and fix the issue and updated through to current version of OS X but to no avail. I have concluded it is a software conflict, perhaps with the intel chip, rosetta etc...
Have looked for fixes online but nothing I can find.
Using SanDisk 2 GB Ultra II and Silicon Power 2GB 80x cards
Am I missing something obvious?
Scott
i made a similar experience (using Lexar Pro 2GB cards, a no-name card reader on OS X 10.4.10). what i found out is that the card reader works fine as long as there is not more than 1 GB on the card. if there is more data on the card, then OS X crashes completeley. i am blaming the card reader (due to lack of another explanation), and plan to replace it eventually.
rgds, bernhard
Seconded. Use mine all the time and they are folded and unfolded several times a day (even use one as a standard USB stick) and I have had no problems at all.
