How do Leica lenses compare to full frame SLR Zeiss lenses?
On 1/8/2020 at 6:07 PM, adan said:
Sample variation, possibly. The 135 TE was made over 32 years (1965-1997). Coatings (and factories) changed over that time, and the older lenses may have developed haze or other age effects to some extent or another, now that they are up to 55 years old. I have definitely run across some "antique" TEs that are duller, or have barrel-wobble (which can affect focus precision or field-flatness).
The picture below is a 100% crop from a Leica M8 (with full frame version inserted) with a "clean" 135 TE of 1970's vintage. Stopped down one stop (f/5.6 - the peak aperture). The fact that it holds up as an effective "800mm," at least for web use (and compressed to .jpg), says something for the resolution.
As to contrast, that depends on whether one means edge- or micro-contrast, or global contrast. The latter can be a two-edged sword on color slide film, or digital.
I like the fact that under raw sunlight, this shot holds separation and detail in the black-paint-in-shadow under the man's thigh, yet does not blow the white shirt (or "emergency-orange" vest) highlights. I generally found the Kyocera Zeisses to be overly-contrasty in Colorado's constant sunshine, even on B&W film (empty shadows and/or blocked highlights, sometimes within the same picture) - one of the reasons I switched to Leica M with (mostly) pre-APO/ASPH lenses 19 years ago.
Well, I inspected my tele-elmar and there was no haze at all.  What I found was a very dusty UV filter.  So I took it off and tried it without the filter, expecting not to notice much difference, but was wrong.  There is a great difference. I tried the lens against the Contax f2.8 in similar lighting situations and I can not say which one is better.
I usually keep UV filters on my lenses with lens hoods and no caps (except when using at night), so they are not always spotless, but I have not noticed any of them affect IQ like I have with the Tele-Elmar. Maybe it is something to do with the construction of this lens, I don't know.  Very surprised.
Leica M lenses generally have much better build quality. They are also much better in terms of digital sensor friendly and/or post processing SW friendly due to the “secrete “ correction formula.  You may call this an unfair game.
I have three Zeiss lenses (1 Contax/Yashica 2 ZM) developed focus ring backlash, two internal fungus, but none of my Leica  has any sign of build quality deterioration, many of my Leica are much older N-th handed.
The Contax/Yashica 28mm wide angle lenses has significant worse distortion than my Leica, and ZM 35mm, 25mm show significant Christmas light effect on digital M, but even the 28-35-50mm Tri-Elmer  is free of that. These should be due to the lack of supported lens correction,
I think in the old film days, Leica M lenses have the advantage of the shorter flange distance due to the lack of mirror, which is hard to be compensated by the larger lens size. Among Zeiss, the Hasselblad much older SWC 38mm Biogon vs. it’s any 40mm  Distagon is a clear example. Moving into digital, the digital sensor imposes more challenges to the  short flange, which requires deeper understanding of the lens correction. Leica again wins with its proprietary on camera lens correction.
Edited by Einst_Stein
I have many Leica Lenses and many Zeiss. It depends on the lens itself. My 21mmf/2.8 ZM is soft in corners. My 35mm f/2.8 ZM is amazing. Both have colours POP out.  I find Leica lenses "flat" Zeiss always has a POP.  I love my Hasselblad Zeiss lenses. If you go to Youtube and seek out the Cinema lens comparisons among Leica Lens and Cooke Lens you will see how the Leica is Flat, This is repeated with Zeiss lenses. I will say I am NOT disappointed with my Leica, Zeiss or Nikon lenses. I use them all. I suggest you concentrate on composition and forget the minor discrepancies. Unless you are doing precise scientific or landscape work. I like to use softer lenses when doing portraits. More painterly. Each subject needs to be interpreted. Thus the Noctilus f/1.0 which to me is the ultimate painterly lens, closely followed by the Zeiss 110mm F/2.0 on a Hasselblad.
I have used all these lenses, so my take on them is...
Zeiss ZF/ZE - typical zeiss, very sharp, suffer some purple fringing (a lot) bokeh has sharp CA laiden edges and very sharp. did i say that? There are exceptions, i have a 135 APO and it's stunning. But most aren't like that.
Zeiss OTUS - very nice, like the 135APO. Huge and heavy
Zeiss Supreme - okay, these are cine, but they're beautiful
Zeiss Contax - vintage but really nice vintage, less sharp than the modern lenses more differences between them so as a set they're not great but some lovely lenses in there
Lecia R - i'm pretty meh about these, prefer contax above
Voightlander - love them, great value
Leica M - just moving into these, because they are better in general. IMHO they feel better in terms of image, the fall off etc,.
YMMV
cheers
Paul
Ă—
Ă—
