21mm Elmarit Asph & frame lines?
teehas53
Can one of you owners out there tell me which lines your 21mm Elmarit Asph triggers? I'm looking to replace the mount on my Zeiss 21/2.8, and I seem to remember that it needs the 28 mount (plus coding) to be read as a 21 Elmarit Asph.
Also, anyone in the US found a resource for replacement Zeiss mounts? I'm having trouble locating one - no answer at all from Zeiss USA...
T
x
T
There are NO 21mm frame lines so what does it matter what lines are brought up by the Ziess or Leica 21mm lens. Or am I missing something here.
I have a CV Skopar 21 f/4 and I find if I use the whole viewfinder it is pretty close. Not sure what framelines come up with the CV lens, never really bothered to look. I have hand coded it and one body reads it and the other doesn't, go figure, irrespective of the framelines that the lens mount brings up.
If one does not wear glasses, the entire area in the viewfinder is about the same as the 21 field. Not exact, but close, and with instant replay of digital, it works for me most of the time. DR
Thanks guys, I get the part about using the finder field without lines to approximate the field of view of a 21.
My question relates to the fact that to get the M8 to recognize a hand-coded lens, it has to detect the same frameline triggering that the comparable Leica lens activates. The black & white dots alone are not enough.
The 21mm Biogon does not trigger the proper framelines, hence making hand-coding impossible. I know I read somewhere a discussion about people changing Zeiss mounts to correct this problem (the Zeiss 25 has the same problem on the M8.)
Now that I know the Elmarit brings up 28/90 lines, I will try to get my hands on a 28mm Zeiss mount...
T
