Andrea Bianchi Posted June 7, 2019 Share #1 Posted June 7, 2019 (edited) Advertisement (gone after registration) Hi everyone, I have an S2 and wanted to buy a Cs lens for my outdoor portraits. I use an Elinchrom Ranger Quadra set with A-Head, does anyone knows if there are any problems using the Cs Shutter with the A-Head? Thanks in advance Edited June 7, 2019 by Andrea Bianchi Link to post Share on other sites More sharing options...
Advertisement Posted June 7, 2019 Posted June 7, 2019 Hi Andrea Bianchi, Take a look here Leica Cs Lens & Quadra A-Head . I'm sure you'll find what you were looking for!
Milan_S Posted June 7, 2019 Share #2 Posted June 7, 2019 no problems at all works fine! only in M mode though.. Link to post Share on other sites More sharing options...
hoppyman Posted June 7, 2019 Share #3 Posted June 7, 2019 I am looking at getting exactly the same. The Action Head is the right version to get, not the HS. You should be able to sync at 1/180 with CS or 1/125 with the normal shutter Link to post Share on other sites More sharing options...
albireo_double Posted June 8, 2019 Share #4 Posted June 8, 2019 No experience with the Quadra but I can highly recommend the Elinchrom ELB 1200 and yes, the Action head is the one to go for (for any camera with leaf shutter lenses). If you get only the Pro head as part of the kit, it also works perfect in 99% of situations (unless you want to freeze fast movement at any power setting, basically). The Quadra system should work perfectly by analogy. 1 Link to post Share on other sites More sharing options...
