jasoniburn Posted June 1, 2019 Share #1 Posted June 1, 2019 Advertisement (gone after registration) Box unpacked and straight out with my brand new (to me) M9P and 50mm Summarit lens today. Love the images I've taken but I have a question. I use Apples Aperture software and in my EXIF data the lens shows as a 50mm focal length but none of my images have the aperture f stop number registered. Any settings I can change in camera or is that just how it is? Link to post Share on other sites More sharing options...
Advertisement Posted June 1, 2019 Posted June 1, 2019 Hi jasoniburn, Take a look here Exif data in Aperture missing f number. I'm sure you'll find what you were looking for!
jasoniburn Posted June 1, 2019 Author Share #2 Posted June 1, 2019 Found out the answer myself 🙂 It's because there is no actual electronic reading that the lens sends to the camera as the lenses as we know are all mechanical. There can be some "guessed" f/ readings interpreted by some software but they are not actual accurate aperture numbers. Link to post Share on other sites More sharing options...
pico Posted June 1, 2019 Share #3 Posted June 1, 2019 (edited) 15 minutes ago, jasoniburn said: Found out the answer myself 🙂 It's because there is no actual electronic reading that the lens sends to the camera as the lenses as we know are all mechanical. There can be some "guessed" f/ readings interpreted by some software but they are not actual accurate aperture numbers. We become accustomed to it. I'm not a savant but I remember the aperture of most pictures of the last forty years largely because I had four commonly used. You may experience the same. Sometimes automation discourages our talent for recall. Edited June 1, 2019 by pico Link to post Share on other sites More sharing options...
vxx Posted June 4, 2019 Share #4 Posted June 4, 2019 On 6/2/2019 at 3:52 AM, jasoniburn said: Found out the answer myself 🙂 It's because there is no actual electronic reading that the lens sends to the camera as the lenses as we know are all mechanical. There can be some "guessed" f/ readings interpreted by some software but they are not actual accurate aperture numbers. Hi, Apple's Aperture (I assume is end product) do not show the F number on exif. However your M9, as with all other digital M bodies, have a sensor on top of the top case to guess the light metering and generate a guess f stop number as you mentioned. Try adobe lightroom for reading the f stop data on exif which works fairly well. Link to post Share on other sites More sharing options...
