PaulJS Posted May 26, 2019 Share #1 Posted May 26, 2019 Advertisement (gone after registration) So I was experimenting with my Q2, shooting raw and jpeg, with the jpeg in monochrome, to see how they were processed. When I imported them into LR, I only saw the color raw images, no monochrome jpegs? What am I doing wrong? 1 Link to post Share on other sites More sharing options...
Advertisement Posted May 26, 2019 Posted May 26, 2019 Hi PaulJS, Take a look here No JPEGs showing up in LR. . I'm sure you'll find what you were looking for!
HighlandK Posted May 26, 2019 Share #2 Posted May 26, 2019 How are your LR preferences set up? Under preferences, General tab if you have a check in "Treat JPEG files next to RAW files as separate photos" both RAW and JPEG should appear side by side once imported. If there is no check in that box they appear one behind the other with the RAW file visible in Library. At least that's how I understand it works. I keep a check in the box so I always see both as separate thumbnails. 1 Link to post Share on other sites More sharing options...
PaulJS Posted May 26, 2019 Author Share #3 Posted May 26, 2019 Thanks HighlandK, that was the issue! Link to post Share on other sites More sharing options...
