amazing journeys Posted May 24, 2019 Share #1 Posted May 24, 2019 Advertisement (gone after registration) What are the best settings for low noise when making images from a moving platform (helicopter} at night With a Kenyon stabiliser The problem is the amount of visible noise in the darker areas of images Camera Leica S 007 35mm lens Settings at 3200 iso.. 250th/500th shutter, 2.5/4.5 aperture Link to post Share on other sites More sharing options...
Advertisement Posted May 24, 2019 Posted May 24, 2019 Hi amazing journeys, Take a look here looking for advise for best camera settings to reduce noise. I'm sure you'll find what you were looking for!
frame-it Posted May 24, 2019 Share #2 Posted May 24, 2019 https://topazlabs.com/denoise-ai/ Link to post Share on other sites More sharing options...
albertknappmd Posted August 8, 2019 Share #3 Posted August 8, 2019 shooting into the dark at ISO 3200 is always going to produce noise. Use one of the post-processing noise reducers to fix it. Albert Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 10 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297586-looking-for-advise-for-best-camera-settings-to-reduce-noise/?do=findComment&comment=3793689'>More sharing options...
peterv Posted August 8, 2019 Share #4 Posted August 8, 2019 I don’t know if you can time and produce your shots like that, but an old trick from the movie business for night-shoots is making sure that the streets are wet so you get lots of reflection to camouflage noise/grain through catching as many specular highlights as you can. Link to post Share on other sites More sharing options...
djmay Posted August 8, 2019 Share #5 Posted August 8, 2019 Several suggestions. 1. Use ISO 400 and increase exposure in processing. Do some tests with the same scene, with camera on the tripod and compare results. 2. Use minimal sharpening. 3. Use high amount of masking so that dark areas are not sharpened. Example with S 006 at ISO 400 https://djessemay.com/images/switzerland/color/Horgen-L1003594-20180727.jpg Regards, Jesse Link to post Share on other sites More sharing options...
albertknappmd Posted August 8, 2019 Share #6 Posted August 8, 2019 doubt he can use 400 ISO from a helicopter.. Link to post Share on other sites More sharing options...
djmay Posted August 8, 2019 Share #7 Posted August 8, 2019 Advertisement (gone after registration) 3 minutes ago, albertknappmd said: doubt he can use 400 ISO from a helicopter.. Location has nothing to do with ISO. Nothing prevents him from using the original shutter speed with ISO 400 and increasing exposure in processing software. Link to post Share on other sites More sharing options...
Joakim Posted August 9, 2019 Share #8 Posted August 9, 2019 Everyone is aware that the question is almost 4 months old? OP has probably already taken that helicopter ride... Link to post Share on other sites More sharing options...
albertknappmd Posted August 10, 2019 Share #9 Posted August 10, 2019 On 8/8/2019 at 1:55 PM, djmay said: Location has nothing to do with ISO. Nothing prevents him from using the original shutter speed with ISO 400 and increasing exposure in processing software. it is not just location.. it is speed, oscillation, vibration, the dark in a HELICOPTER etc... doubt you can obtain much at 400.. Albert 1 Link to post Share on other sites More sharing options...
Photon42 Posted August 11, 2019 Share #10 Posted August 11, 2019 @Albert: Jesse talks about underexposure the frame by a some stops (ISO 400 rather than 1600), then pushing the equivalent in post (+2). This technique was known to be better for M9 CCD sensors, and probably as well for the S2 and S 006. I have tried this suscessfully myself with the M9. Link to post Share on other sites More sharing options...
