Kevin C Posted May 18, 2019 Share #1 Posted May 18, 2019 Advertisement (gone after registration) Flash on my me D Lux 7 is set to off but is greyed out in the settings with the message ‘This menu item can’t be set’. I cannot seem to figure it out. Any ideas? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 18, 2019 Posted May 18, 2019 Hi Kevin C, Take a look here D Lux 7 Flash. I'm sure you'll find what you were looking for!
DaveMo Posted May 27, 2019 Share #2 Posted May 27, 2019 Try looking at the "Typ 109 Flash Problem" post which is a couple down from your (at the mo) as it could be you have the camera set to "Silent Shutter" which stops the flash from operating. Link to post Share on other sites More sharing options...
Photoderm Posted May 27, 2019 Share #3 Posted May 27, 2019 Thanks. I saw that and changed it from the silent mode and the issue persists. Link to post Share on other sites More sharing options...
DaveMo Posted May 27, 2019 Share #4 Posted May 27, 2019 OK, thanks I have a typ109 so there might be a change in the operating system that prevents it from operating if another function is/is not enabled. Let us know when you get it worked out. Link to post Share on other sites More sharing options...
Photoderm Posted May 27, 2019 Share #5 Posted May 27, 2019 Will do Link to post Share on other sites More sharing options...
Kernal Posted November 29, 2019 Share #6 Posted November 29, 2019 On 5/18/2019 at 11:11 PM, Kevin C said: Flash on my me D Lux 7 is set to off but is greyed out in the settings with the message ‘This menu item can’t be set’. I cannot seem to figure it out. Any ideas? Thanks. I’m having this issue. Just bought D-Lux 7 and wondering if anyone has an answer. Shutter not set to silent. Link to post Share on other sites More sharing options...
Tacopoke Posted March 27, 2020 Share #7 Posted March 27, 2020 Advertisement (gone after registration) I’m having the same issue as well. The flash used to work and today it just wouldn’t. Tried the suggestion to turn shutter to silent and it made no difference. Please help, thanks. Link to post Share on other sites More sharing options...
Kernal Posted March 27, 2020 Share #8 Posted March 27, 2020 1 hour ago, Tacopoke said: I’m having the same issue as well. The flash used to work and today it just wouldn’t. Tried the suggestion to turn shutter to silent and it made no difference. Please help, thanks. I got mine to work by going into the menu and doing a reset. I don’t know why but the flash then worked. Link to post Share on other sites More sharing options...
