samwong.aust Posted April 1, 2019 Share #1 Posted April 1, 2019 Advertisement (gone after registration) Any practical experience. Does this combination actually work? Thank you . sam. Link to post Share on other sites More sharing options...
Advertisement Posted April 1, 2019 Posted April 1, 2019 Hi samwong.aust, Take a look here Compatibility of Leica x vario and Leica sf58 flash. I'm sure you'll find what you were looking for!
dkCambridgeshire Posted April 2, 2019 Share #2 Posted April 2, 2019 (edited) There are TWO versions of the SF58 … each has different firmware. I have used the XV and SF58 with V2 firmware in 45º bounce flash mode and with the built-in white plastic bounce card and images were fine. The SF 58 with V1 firmware may not be compatible. V2 firmware is not updatable or available for a V1 firmware SF58. The disadvantage of using any flash in the XV shoe is that composition relies on the monitor rather than the EVF … which at an event can make the photographer appear to look a little odd as he/she holds the camera at at arms' length. This image taken using the XV with SF58 dunk Edited April 2, 2019 by dkCambridgeshire typo Link to post Share on other sites More sharing options...
samwong.aust Posted April 2, 2019 Author Share #3 Posted April 2, 2019 Thank you for the comprehensive answer, most appreciated. A very good picture indeed. I will try to get a v2 of the sf58 if possible. Have a wonderful day . Best wishes. Sam . Link to post Share on other sites More sharing options...
