gareth_c Posted July 21, 2007 Share #1 Â Posted July 21, 2007 Advertisement (gone after registration) Sorry if a similar issue has been discussed before, I did a search but couldn't find anything. Â So, I took my M8 along with me yesterday to meet some friends for a drink. All fun so far, except... Â I was using the camera at f2 (35 summicron), 1250 ISO and the camera still insisted on exposures of between 4 and 8 seconds. Now, I knew it was dark in there but it wasn't that dark. My friend had his D200 along and when we tried a similar set up his camera defaulted to 1/2 second. Â My results were totally over exposed and obviously just a blurry mess! Â When I manually set the shutter speed I was just getting black frames, even at 1 second. Â I turned the camera off for a bit, had a drink then took some shots outside...everything seemed back to normal. I went back inside, to exactly the same position, in the same conditions, tried again and suddenly got acceptable results at 1\2 second. Â Quite what was happening the first time I can't work out. Has anyone had similar problems? Link to post Share on other sites More sharing options...
Advertisement Posted July 21, 2007 Posted July 21, 2007 Hi gareth_c, Take a look here Shutter speed Madness?. I'm sure you'll find what you were looking for!
rwfreund Posted July 21, 2007 Share #2 Â Posted July 21, 2007 Only when I forget to remove my lens cap. -bob Link to post Share on other sites More sharing options...
Shootist Posted July 21, 2007 Share #3 Â Posted July 21, 2007 Yes I have but I don't remeber where it was. I think I was outside in good light and the shutter speeds were 1/30-1/60 which made the shots totally OE. Hasn't happened since that I recall. Link to post Share on other sites More sharing options...
Gid Posted July 21, 2007 Share #4 Â Posted July 21, 2007 Happened to me. The cause was that the shutter speed dial had been knocked from A to B, not all the way, just slightly off of A. Of course your's may not be the same problem. Link to post Share on other sites More sharing options...
fordfanjpn Posted July 21, 2007 Share #5 Â Posted July 21, 2007 Happened to me only once. Just one shot in a series of shots in fairly low light was totally overexposed. Almost entirely white with just a couple of blurry gray spots here and there. Shots before and after were fine, and I didn't touch anything except focus while I was shooting. Â Bill Link to post Share on other sites More sharing options...
Guest Walt Posted July 21, 2007 Share #6 Â Posted July 21, 2007 My M8's--I've had five of them to get the two I now use--have all been inclined to occassionally badly overexpose the first frame when coming out of standby. When I trace back the camera usage, they seem to be "holding on" to the previous exposure before they went into "sleep." A lot of quotation marks here, a lot of mystery. So, I'd say just immediately try another frame, because the second one is normal. Â Walt Link to post Share on other sites More sharing options...
Guest WPalank Posted July 21, 2007 Share #7 Â Posted July 21, 2007 Advertisement (gone after registration) Same as Gideon. I had accidentally bumped the dial off of Aperture Priority. Link to post Share on other sites More sharing options...
