Cowz Posted December 8, 2018 Share #1  Posted December 8, 2018 Advertisement (gone after registration) OK..... Leica flash newbie here and I apologise if this has been rehashed, but I could not find this problem/combination anywhere.  All literature indicates both units are HSS capable. I have my SL setup,with a SFC1 controller triggering a SF60.  I am trying to overcome ambient light in areas where the background can blow out, such as outdoors using low fstops. They work well together in TTL and M modes up to 1/250s. When I venture into HSS country, my SFC1 indicates HSS is active but the SF60 does not operate at all..... It almost seems as there is a HSS mode on the flash that is not operating.  I wonder if the HSS capability of the SF60 only works when the flash is mounted above the camera???? HELP!!!!!!! PS...... I want to use this combination on my M10 too.   Link to post Share on other sites More sharing options...
Advertisement Posted December 8, 2018 Posted December 8, 2018 Hi Cowz, Take a look here HSS with SFC1 and SF60. I'm sure you'll find what you were looking for!
sillbeers15 Posted December 8, 2018 Share #2 Â Posted December 8, 2018 (edited) Check if your SF C1 Commander is set to 'M' on 'M/TTL' button for shutter speeds > 1/250 sec when 'HSS' is indicated on commander. The issue has been feedback to Leica but Leica has yet to offer a solution. Same issue on M10. It seems to be fine with Q. For HSS to work on M10 & SL through SF40 (directly hot shoe mounted only) and SF60 (hot shoe mounted & via SF C1), the flash must be in TTL mode only. Edited December 8, 2018 by sillbeers15 2 Link to post Share on other sites More sharing options...
