Hi Everyone
I originally posted in the "How To" but after a week or so no answer i would like to try here. When i changed my lens to the 35/1.4 the little battery life indicator went out of the EVF. I do not know how much battery i have left. I changed back to the 18-55 and it is still not in the EVF. I turned off the camera and put it back on and the indicator was on the top for a moment and then went away.
How do i keep the indicator in the EVF  ?
Thank you
If you are referring to the CL, temporary display of battery status shows briefly in the top panel before giving way to a mode display. I can live with that routine. In the EVF,  information displayed can be toggled on or off by depressing the info button in keypad central. I hope that helps you.
Same with my M10.
Changing lens or battery made no difference.
Updated to Firmware 2.6.5.0 made no difference.
Might have forgotten how to display battery status... haven't used the M10 for a while.
13 minutes ago, ttliem said:
Same with my M10.
Click once on the center of directional pad on the back.
Edited by pico
1 minute ago, ttliem said:
Thanks. That's the simple procedure I forgot. Feeling very stupid right now...
I messed up at first by just holding it down. Didn't work. Must 'click'. :)
