Not sure one can move backward in terms of firmware spec.  With  LR CC 7.5 and M10 2.4.5.0 there are dozens of profiles.  7 core Adobe supplied 6 color. 1 BW)  + the M10 profile along with a series of presets, 20 color and 17 monochrome.
I've not noticed any trouble with the 21mm SEM lens profile, but I'll go back and check.
...I checked. I can clearly see reduced field curvature with the profile checked.  Works for me.
There is a bug in LR 7.5 and perhaps since 7.3 that affects M 262 cameras: The "Embedded" camera profile does not appear as one of the many options. I'm curious if that profile is available with your M 10 in LR 7.5. Can you check and post the result here? Thanks!
I hadn't noticed, but as it turns out the Q does not display an Embedded profile either. Curious, as the M10 does. Heres what my menu displays, hope this helps.
