grahamc Posted August 20, 2022 Share #1081 Posted August 20, 2022 Advertisement (gone after registration) 35:1.4 v2, MP, Portra 400 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 15 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4493325'>More sharing options...
Advertisement Posted August 20, 2022 Posted August 20, 2022 Hi grahamc, Take a look here 35mm 1.4 Summilux pre-asph. I'm sure you'll find what you were looking for!
grahamc Posted August 20, 2022 Share #1082 Posted August 20, 2022 (edited) 35:1.4 v2, M6 TTL, Cinestill 50D Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 20, 2022 by grahamc 11 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4493338'>More sharing options...
evikne Posted August 26, 2022 Share #1083 Posted August 26, 2022 M10 w/35mm Summilux pre-ASPH v2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 8 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4497086'>More sharing options...
evikne Posted August 26, 2022 Share #1084 Posted August 26, 2022 M10 w/35mm Summilux pre-ASPH v2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 9 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4497092'>More sharing options...
Aryel Posted August 26, 2022 Share #1085 Posted August 26, 2022 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph (v2 Canada), rollei retro 400s, r09 1+50 printed on mgfb warmtone and scanned 18 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph (v2 Canada), rollei retro 400s, r09 1+50 printed on mgfb warmtone and scanned ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4497327'>More sharing options...
hdmesa Posted August 30, 2022 Share #1086 Posted August 30, 2022 SL2-S -|- 35 Lux Pre-ASPH v2 -|- f/1.8 -|- macro adapter Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4499965'>More sharing options...
hdmesa Posted August 31, 2022 Share #1087 Posted August 31, 2022 (edited) Advertisement (gone after registration) Warning to those of us using a general 49mm filter inserted into the 12504 hood: it will cause vignetting and smearing in the far corners at infinity. Not sure if this affects any other version of the pre-ASPH other than the v2, which I have, but I would assume so. A visual as to why below. The correct Series VII filters (left) only have a very narrow outer band holding the glass, while most all 49mm filters have a wide inner band. This wider band is just enough to protrude into the light path. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 100% zoom to the top left corner of an image taken with and without the B+W filter (same result in all four corners). I moved the camera between shots, so ignore the clouds changing position. Ignore the camera-estimated aperture in the EXIF – the same f-stop of f/5.6 was used for both shots in order to reduce vignetting from the lens itself. Edited August 31, 2022 by hdmesa 6 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! 100% zoom to the top left corner of an image taken with and without the B+W filter (same result in all four corners). I moved the camera between shots, so ignore the clouds changing position. Ignore the camera-estimated aperture in the EXIF – the same f-stop of f/5.6 was used for both shots in order to reduce vignetting from the lens itself. ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4500162'>More sharing options...
Aryel Posted August 31, 2022 Share #1088 Posted August 31, 2022 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph (v2 Canada), rollei retro 400s, r09 1+50, printed on mgfb warmtone and scanned 9 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph (v2 Canada), rollei retro 400s, r09 1+50, printed on mgfb warmtone and scanned ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4500394'>More sharing options...
hdmesa Posted September 4, 2022 Share #1089 Posted September 4, 2022 Test footage on the SL2-S, B&W HC film style, shot at f/1.4, 120fps HD Leica SL2 S -|- Leica 35 Lux Pre-ASPH v2" width="200"> 11 Link to post Share on other sites More sharing options...
mikeyknob Posted September 4, 2022 Share #1090 Posted September 4, 2022 On 8/4/2022 at 10:23 AM, chasdfg said: This thread is making me want to pull the trigger on a late v2 German copy. I tested 1 German copy (not the same as the one I'm eyeing) side by side with a Canada one and I was surprised to see the central sharpness of the German one to be higher than the Canada one. I didn't test sharpness in the corners or stopped down. I tried to find this info on the web but couldn't find it - does anyone know the weight of the lens with a hood and filter? Also, is focus shift an issue with this lens? I plan to use it wide open but would stop it down readily as there's no size penalty disadvantage if I do so. I took a while to find a late-ish German copy (serial number 35xxx onwards, though I'm not sure when they became "sharp" due to tweaks in coatings or whatever they did so i figured just to look out for those at the end of production)..it was almost as if the titanium ones are easier to find...but not as easy on the wallet. I prefer a black lens but I do see the appeal of the titanium version. Whatever is cheaper is the one for me - either way I wish I picked one of these lenses up earlier! Totally in the same place and a little tortured about an 80’s black Canadian one vs. a 90’s Titanium German one. Both are now really expensive (thanks to this thread? 😅)… and they’re both appealing for different reasons. Appreciate everyone here posting thoughts and images. Any further “if I could only have one” insight would be appreciated, too. Thanks, everyone. Link to post Share on other sites More sharing options...
egrossman Posted September 4, 2022 Share #1091 Posted September 4, 2022 1 hour ago, mikeyknob said: Totally in the same place and a little tortured about an 80’s black Canadian one vs. a 90’s Titanium German one. Both are now really expensive (thanks to this thread? 😅)… and they’re both appealing for different reasons. Appreciate everyone here posting thoughts and images. Any further “if I could only have one” insight would be appreciated, too. Thanks, everyone. Finding a reasonably priced late-German copy (mine was from 1991) was a challenge. I ended up finding one in very good condition in London for slightly over $3,000 (the strength of the dollar helped). It was shipped by DHL to me in the Bay Area. I concur with the comments above. My copy glows a little wide open but is overall pretty sharp considering the lens. Erik 1 Link to post Share on other sites More sharing options...
evikne Posted September 4, 2022 Share #1092 Posted September 4, 2022 11 hours ago, hdmesa said: Test footage on the SL2-S, B&W HC film style, shot at f/1.4, 120fps HD Very cool to see this lens used for moving pictures! 3 1 Link to post Share on other sites More sharing options...
hdmesa Posted September 4, 2022 Share #1093 Posted September 4, 2022 (edited) 1 hour ago, evikne said: Very cool to see this lens used for moving pictures! Thanks! Shooting short test videos at maximum aperture really helps me visualize the character of a lens like this. Edited September 4, 2022 by hdmesa 3 Link to post Share on other sites More sharing options...
Aryel Posted September 5, 2022 Share #1094 Posted September 5, 2022 9 hours ago, mikeyknob said: Totally in the same place and a little tortured about an 80’s black Canadian one vs. a 90’s Titanium German one. Both are now really expensive (thanks to this thread? 😅)… and they’re both appealing for different reasons. Appreciate everyone here posting thoughts and images. Any further “if I could only have one” insight would be appreciated, too. Thanks, everyone. Condition is more important than German or Canada. Go with the better one. I have a crystal clear Canada version and I am really happy with it. I bought this lens for its unique character at f1.4 and f2 and it delivers. From the comments above, the German version may have less of it so it clearly is not for me. In any case, I’d be surprised if anyone can guess between the two versions on a blind test… This is just my opinion 😉 5 Link to post Share on other sites More sharing options...
sinjun Posted September 5, 2022 Share #1095 Posted September 5, 2022 On 9/4/2022 at 6:44 AM, hdmesa said: est footage on the SL2-S, B&W HC film style, shot at f/1.4, 120fps HD This is excellent - very effective. 1 1 Link to post Share on other sites More sharing options...
Fjäll Posted September 7, 2022 Share #1096 Posted September 7, 2022 Does anyone know if the Leica ITDOO hood will vignette on the V2? V2 + M9 SOOC Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4504738'>More sharing options...
yofred Posted September 8, 2022 Share #1097 Posted September 8, 2022 Can someone tell me more about this filter for the v1? Ye sold it to me but I didn’t come across any examples of it online. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4505194'>More sharing options...
grahamc Posted September 8, 2022 Share #1098 Posted September 8, 2022 MP , 35:1.4 v2 & Portra 400 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 10 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4505432'>More sharing options...
Aryel Posted September 8, 2022 Share #1099 Posted September 8, 2022 12 hours ago, yofred said: Can someone tell me more about this filter for the v1? Ye sold it to me but I didn’t come across any examples of it online. Looks like a standard filter. Maybe odd sizes to not have the outer engraving? I’d suggest to post in the ‘historica’ section. You may have more replies there… Link to post Share on other sites More sharing options...
Aryel Posted September 8, 2022 Share #1100 Posted September 8, 2022 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph v2, rollei retro 400s, r09 1+50, printed on mgfb warmtone and scanned 14 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! m3, summilux 35 pre-asph v2, rollei retro 400s, r09 1+50, printed on mgfb warmtone and scanned ' data-webShareUrl='https://www.l-camera-forum.com/topic/288041-35mm-14-summilux-pre-asph/?do=findComment&comment=4505497'>More sharing options...
