Leicalifer Posted April 14, 2018 Share #1 Posted April 14, 2018 Advertisement (gone after registration) Hello Any long term user reports or comments on the S handgrip? Looks handy for studio use with grip strap. Not sure there is an L plate for one, then again I doubt if I would need to instanatly go from handheld to tripod without a short break for some type of set up, review and maybe a lens change. As always, Thank you in advance for all the great advice. Link to post Share on other sites More sharing options...
Advertisement Posted April 14, 2018 Posted April 14, 2018 Hi Leicalifer, Take a look here S handgrip 16028 . I'm sure you'll find what you were looking for!
John McMaster Posted April 14, 2018 Share #2 Posted April 14, 2018 I use my S2-P and S(007) with battery grips, much prefer it for hand-held usage. With the RRS grip, it throw the lining-up with the LHS connectors so usually take the grip off when using a tripod. john 1 Link to post Share on other sites More sharing options...
Leicalifer Posted April 14, 2018 Author Share #3 Posted April 14, 2018 John Thank you, just as I thought. When using the handgrip, do you have a preferred hand strap? Link to post Share on other sites More sharing options...
John McMaster Posted April 14, 2018 Share #4 Posted April 14, 2018 I use the Leica ones, main problem is that if you use the neck strap as well only one will fot through the camera eye. I have my neckstrap on a 35mm SLR type ring through the S eye as well as the grip strap. When I put on a tripod I just unscrew the grip from the camera and leave it hanging. john Link to post Share on other sites More sharing options...
darylgo Posted April 15, 2018 Share #5 Posted April 15, 2018 I'm not sure I understand the question, but Leica has said the grip should not be used on a tripod, it is not intended for this. My understanding is the grip is not substantial enough for the forces exerted by a camera and lens combination. That is the reason there are no L plates for the grip. My limited testing showed the combination was ok to use but weakness was detected and I never tried again fearing a poorly supported camera and lens could break the connection to the grip. Leica has no restrictions with the SL grip, it is metal/sturdy whereas the S grip doesn't have the build quality and feels plasticy. 1 Link to post Share on other sites More sharing options...
Leicalifer Posted April 15, 2018 Author Share #6 Posted April 15, 2018 Darylgo Sorry for the confusion. Your post answered my questions. I assumed the build quality was similar to the SL grip and was perplexed why no one offered a suitable model. Thanks for the clarification. Link to post Share on other sites More sharing options...
