dancook Posted January 22, 2018 Share #1 Posted January 22, 2018 (edited) Advertisement (gone after registration) I have this https://www.essentialphoto.co.uk/product/pixapro-citi600-manual-battery-powered-twin-flash-kit/ and a Canon transmitter https://www.essentialphoto.co.uk/product/pixapro-eco2-point-4-2-point-4ghz-32-channel-flash-trigger/?product_options[Camera+System]=Nikon it won't fire HSS "The HSS on the ECO trigger would automatically activate when it goes above the camera sync speed." They only have Canon/Nikon transmitter - how should I get HSS to work on the Leica M10? I will try the Nikon trigger, but I am not hopeful - but at least it'd work if I then bought a D850. thanks Edited January 22, 2018 by dancook Link to post Share on other sites More sharing options...
Advertisement Posted January 22, 2018 Posted January 22, 2018 Hi dancook, Take a look here Unable to fire HSS. I'm sure you'll find what you were looking for!
sillbeers15 Posted January 22, 2018 Share #2 Posted January 22, 2018 For proper HSS to work, the flash or strobe needs a signal from the camera to inform the lighting to go into mutiple pulse mode. I am not aware of any wireless trigger in the market today can successfully trigger OCF at TTL & HSS. Prolite can be triggered at HS inmanual mode. Only single pin contact can consistently fire OCF in manual mode at 1/250 sec when SL set to M mode (some flash & trigger combination can trigger at 1/320sec max). 1 Link to post Share on other sites More sharing options...
