Mike G. Posted January 9, 2018 Share #1  Posted January 9, 2018 Advertisement (gone after registration) I've had this unit for over tens years. Since switching to the R9 w/ Digital Modul - R it's been sitting idle. I recently re-built the re-chargeable battery pack that went dead a while ago because I wanted to use the R8 which I still have for film. The problem is that the off switch on the camera is giving me erratic problems which I can't figure out. With the battery pack fully charged (all three LED's lit), if I switch the camera on to m (manual mode), the shutter fires. If I stay in m mode all functions of the camera work including Singe frame, Continuous Low and Continuous High. When I switch from m to A (aperture mode), the shutter won't fire unless I open the back of the camera and then close it again. But this doesn't happen every time and not just between m and A. It could occur going from any mode to another, m, A, P, T and F, again not every time. I checked the camera using the battery holder it came with and also with the R8 Motor Winder and the switch and camera function flawlessly in all modes, so I can only assume it's the MD-R8. I cleaned all of the gold plated contacts on both the camera and the drive to no avail. Link to post Share on other sites More sharing options...
Advertisement Posted January 9, 2018 Posted January 9, 2018 Hi Mike G., Take a look here MOTOR DRIVE MD-R8 Problem. I'm sure you'll find what you were looking for!
