Why would it change without you turning a dial?
By default I believe it requires multiple button presses. I have mine set up for the top dial to control it with no other button presses and I’ve never accidentally adjusted it.
Also you can view the meter in the EVF or back screen as well as the photo you’re going to end up with so you should see the over/ under exposure before firing the shutter.
