lpeeples Posted December 30, 2017 Share #1 Posted December 30, 2017 (edited) Advertisement (gone after registration) I have a M10, M6, SL, and MM1 CCD mono. My 35 pre asph works fine on all the bodies except the mono. When I put that lens on the mono, and try to focus to infinity, the focus starts to get “stuck” just before infinity and doesn’t go all the way unless I force it. All my other lenses work fine on the Mono and the 35 is fine on all the other bodies? Wondering if its the lens or body that needs adjusting? I have a M10, M6, SL, and MM1 CCD mono. My 35 pre asph works fine on all the bodies except the mono. When I put that lens on the mono, and try to focus to infinity, the focus starts to get “stuck” just before infinity and doesn’t go all the way unless I force it. All my other lenses work fine on the Mono and the 35 is fine on all the other bodies? Wondering if its the lens or body that needs adjusting? Edited December 30, 2017 by lpeeples Link to post Share on other sites More sharing options...
Advertisement Posted December 30, 2017 Posted December 30, 2017 Hi lpeeples, Take a look here Focusing issue with 35 pre. I'm sure you'll find what you were looking for!
pico Posted December 30, 2017 Share #2 Posted December 30, 2017 (edited) I have a M10, M6, SL, and MM1 CCD mono. My 35 pre asph works fine on all the bodies except the mono. When I put that lens on the mono, and try to focus to infinity, the focus starts to get “stuck” just before infinity and doesn’t go all the way unless I force it. All my other lenses work fine on the Mono and the 35 is fine on all the other bodies? Wondering if its the lens or body that needs adjusting? You have four Leica bodies and one combination seems problematic: the Mono & 35mm Summilux. Can we presume your other lenses fit and focus properly on all four bodies? The question seems to answer itself. . Edited December 30, 2017 by pico Link to post Share on other sites More sharing options...
Sergius Posted December 30, 2017 Share #3 Posted December 30, 2017 lpeeples, your 35 summilux is one of not compatible lens with M9 or MM. You need to carefully mount the lens. Be sure not to have it focused at infinity !!! Don't use the lens. You have a version of this lens that will need grinding down. The black shroud will hit the inside of the M8 and M9 when focused at infinity. Check the manual of Monochrom !!! 2 Link to post Share on other sites More sharing options...
lpeeples Posted December 30, 2017 Author Share #4 Posted December 30, 2017 (edited) lpeeples, your 35 summilux is one of not compatible lens with M9 or MM. You need to carefully mount the lens. Be sure not to have it focused at infinity !!! Don't use the lens. You have a version of this lens that will need grinding down. The black shroud will hit the inside of the M8 and M9 when focused at infinity. Check the manual of Monochrom !!! Thank you... Any idea if that will cause the lens to be problematic with other bodies? Edited December 30, 2017 by lpeeples 1 Link to post Share on other sites More sharing options...
Sergius Posted December 30, 2017 Share #5 Posted December 30, 2017 (edited) Thank you... Any idea if that will cause the lens to be problematic with other bodies? I don't think so. Maybe only on M10. But check the manual. In any case I suggest to you to modify the lens. It's amazing on MM. Edited December 30, 2017 by Sergius Link to post Share on other sites More sharing options...
lpeeples Posted December 30, 2017 Author Share #6 Posted December 30, 2017 Got it, found the note in the manual, thanks 1 Link to post Share on other sites More sharing options...
Etruscello Posted January 15, 2018 Share #7 Posted January 15, 2018 Advertisement (gone after registration) Sergius is correct: the 35mm Summilux-M pre-Asph mount must be modified to focus properly and achieve infinity focus on the MM. My 35 pre was modified by DAG. He did a careful, precise and beautiful job. He ground down the mount only where necessary so that the lens could still be placed mount-down on a table without damage to the rear lens element. I sent Don Goldberg a mint lens and he returned a mint lens. You can use DAG with confidence. (Just Google Don Goldberg at DAG.) Tom Link to post Share on other sites More sharing options...
