More Wate Menu Problems...
atufte
My Dremel coded adapter and CV15 has worked flawlessly for a while, until the last few weeks, all of a sudden the Wate menu starts popping up between every shot, very annoing indeed, anyone else seen this...?
Thanks
You mean when the camera comes on? That is normal for lens detection "On + IR".
No, i mean it comes on after each shot...i know it's suppose to come up when i turn the camera on....but thanks anyway :-)
alexander:
my first tests with the coded 15mm Helia worked great. I had cut recesses in a Leica thread to m adapter.
Until I went out into bright sun for the first time, and then started getting erratic menu and exif behaviour. the problem was light leaking due to the tiny step in the Leica flange. the led to the development of the made from scratch coded adapters that are light tight.
I suggest you do a test in bright light and dim light (or somehow cover the potentil leaking area with tape) to see if that effects the menu behaviour
Thanks Jim, i was shooting in bright sunlight so that might just be it, i will try later, and of course i want to buy one of your adapters, but i'm on a real tight budget at the moment, building a new kitchen, and bathroom is expensive :-) So until that's done, i will have to use the macgyver method :-)
Thank you anyway :-)
