Focus peaking when using R lenses
Leicalifer
Thinking of trying my 60 mm R macro lense on the SL with the Leica R to sl adapter, but I haven't bought the adapter yet. Out of curiosity, Does focus peaking work with R lenses on the SL similar to the way S lenses provide focus peaking information to the shooter when mounted on the Sl via the S to Sl adapter?
Focus peaking is sensor based so it should work on any lens, whatever the adapter. Older low contrast lenses however don't work quite as well .... but you can adjust FP sensitivity to compensate to some extent. The R 60 should work fine .... although for actual macro work I would use the magnification option to focus.
