Bulb mode question
albertknappmd
The S2 and the 006 had the option of setting up a timer in BULB mode.
You set the camera to manual mode, then adjust to B and depress the wheel on the back and you see a time screen on the LCD that you can modify by rotating the wheel.
I tried this on both of my 007s and......................... nothing.
Any ideas?
Albert
Since the 007 doesn't have a shutterspeed dial that has 'fixed' settings... you can just use the button to turn from 1/4000 to 60 seconds ;)
60 seconds is the maximum the Leica S 007 can do at ISO 100.
So the 007 has a "button" at the top deck which you can turn right? The round dial used to set shutterspeed? And on the back it has the thumb dial for aperture.
Set the camera in M mode (by pressing the thumb dial)
Then adjust the shutter speed with the round dial at the top deck to choose any shutter speed from 1/4000 to 60 seconds :)
Hope that helps! :)
Jip
