Summaron 35 2.8 Coating Loss
memorylane
I have a coating loss on the front element, which is about 3mm side to side and 4 mm top to bottom.  I read somewhere that a fleck of coating loss isn't critical as it only contributes to more flare.  A haze would consider to be more critical than slight coating loss.
Should i be concern or leave it as is?  Will more coating come off?
The coating is important in tamig glare, use a hood and you should be ok unless you are shooting directly into the light. OTOH, you can always have the lens recoated by someone like John Shelton at Focal Point (if your pocket book is deep enough) www.focalpointlens.com/
