salvi Posted June 26, 2007 Share #1 Posted June 26, 2007 Advertisement (gone after registration) Dear Leica friends I just bought a R7 and I started to do some comparison to my R8. I discovered that the integral metering of the R7 gives about 1 stop less of exposure than the R8...selective metering mode is almost the same. Can you confirm me that with a short comparison of your cameras..? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted June 26, 2007 Posted June 26, 2007 Hi salvi, Take a look here R7 Metering . I'm sure you'll find what you were looking for!
flyboy Posted June 26, 2007 Share #2 Posted June 26, 2007 Hello Salvatore, I can confirm your impression. My R7 compared to my R9 has the same behaviour. Since I am using slide film like Velvia 100F, the R7 metering is perfect for this kind of film. If I am using this film in the R9 I correct the exposure -0.7. Hope I could help you a little.... RGDS Christof Link to post Share on other sites More sharing options...
salvi Posted June 26, 2007 Author Share #3 Posted June 26, 2007 Thanks Christof So in my case I will have to correct the exposure to +0,5 or +1 when using simple negative films in P or T mode, or just use the A mode in selective metering. RGDS Link to post Share on other sites More sharing options...
flyboy Posted June 27, 2007 Share #4 Posted June 27, 2007 Buon Giorno Salvatore, Yes, that´s the way it will work out for you. RGDS Christof Link to post Share on other sites More sharing options...
zapp Posted June 27, 2007 Share #5 Posted June 27, 2007 Dear Leica friends I just bought a R7 and I started to do some comparison to my R8. I discovered that the integral metering of the R7 gives about 1 stop less of exposure than the R8...selective metering mode is almost the same. Can you confirm me that with a short comparison of your cameras..? Thanks If two cameras show different readings, it is impossible to judge which one is off - even if other people have similar impressions. Try to work out a controlled setup and check with a decent light meter. You need some kind of reference to judge which camera is off. Or take a roll of slide film with each camera and judge from that which looks better. Link to post Share on other sites More sharing options...
