Deliberate1 Posted July 20, 2017 Share #1 Posted July 20, 2017 Advertisement (gone after registration) Friends, I would be interested to hear what your strategies are for shooting the 006, or even the S2 and 007, in hand-held low-light circumstances. Coming from the M9, I was well aware of the inherent limitations posed by ISO settings that are best left below 800, unless, perhaps if the images will be monochrome. With the M9, and as I am learning with the S, one can set the ISO to the fastest acceptable level, say 800, then set the shutter speed so as to reflect hand-held shooting and set aperture to maximum. Images are likely to be underexposed, and substantially so. But given the quality and flexibility of S files, in particular, I find that I can push them in PP at least two stops, and sometimes more. That said, the effectiveness of this technique depends greatly on the nature of the image. I find that shadow detail will likely be non-existent or present with significant noise, which may be acceptable and even favored for B&W images. Any other suggestions? Cheers. David Link to post Share on other sites More sharing options...
Advertisement Posted July 20, 2017 Posted July 20, 2017 Hi Deliberate1, Take a look here Low light shooting techniques. I'm sure you'll find what you were looking for!
mgrayson3 Posted July 20, 2017 Share #2 Posted July 20, 2017 I have nothing to add concerning technique, but I find that low light images look better dark, and I prefer leaving the shadows black, because thats how it looked! The "show all 15 steps of dynamic range" pictures look bizarre except in certain special circumstances. I regularly shoot at ISO 1600 in color with the (006). For example --Matt Link to post Share on other sites More sharing options...
djmay Posted July 20, 2017 Share #3 Posted July 20, 2017 I usually go no higher than ISO 400 in camera. If necessary, I increase exposure in Lightroom. I also use two second delay to enable slower shutter speed. Of course, this will not work with moving subjects. Jesse Sent from my Lenovo YT3-850L using Tapatalk Link to post Share on other sites More sharing options...
albertknappmd Posted July 20, 2017 Share #4 Posted July 20, 2017 with the 006, 400 ISO was my max with the 007, 800 ISO is safe and 1600 is in the danger zone. This is the only limitation but it is substantial. So it goes, Albert Link to post Share on other sites More sharing options...
Milan_S Posted July 20, 2017 Share #5 Posted July 20, 2017 I happily use ISO 1.200 with my S2 no problem with current LR. S2 Contax 35mm f3.5 - ISO 1200 f3.5 f3.5 1/60 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/274632-low-light-shooting-techniques/?do=findComment&comment=3319682'>More sharing options...
Deliberate1 Posted July 20, 2017 Author Share #6 Posted July 20, 2017 I also use two second delay to enable slower shutter speed. Jesse, I assume this means you use a two second timer to give you that amount of time to brace/stabilize? Good suggestion. David Link to post Share on other sites More sharing options...
alan.y Posted July 20, 2017 Share #7 Posted July 20, 2017 Advertisement (gone after registration) Jesse, I assume this means you use a two second timer to give you that amount of time to brace/stabilize? Good suggestion. David Right, and also mirror flip-up. Link to post Share on other sites More sharing options...
LorenzoLandini Posted July 20, 2017 Share #8 Posted July 20, 2017 Depending on the subject and following up on Jesse's suggestion, I have to say that in low light situation I don't mind using my "landscape" setting, which besides being all manual it has a 2 sec delay and mirror lock up. In that way, I am able to shoot at 1/30sec with the S. The first time I did accidentally as I forgot to change the pre-settings, though I realized afterwards that by not having the mirror slamming I can use slower speeds. The viewfinder is darkened during those two seconds and a lot of things can happen in the meantime, but in those rare occasions that I am shooting at night with no tripod and no flash there are subjects that don't move much anyway (..buildings, citiscapes, etc.) and others that move too quickly anyway (people blinking eyes, changing expression, etc.). cheers, lorenzo Link to post Share on other sites More sharing options...
Deliberate1 Posted July 20, 2017 Author Share #9 Posted July 20, 2017 All good ideas, gents. Cheers. David Link to post Share on other sites More sharing options...
Jeff S Posted July 20, 2017 Share #10 Posted July 20, 2017 This technique from our old friend Lars can assist with many cameras.... https://www.l-camera-forum.com/topic/111304-tripod-monopod-nothing/?do=findComment&comment=1209129 Jeff Link to post Share on other sites More sharing options...
djmay Posted July 21, 2017 Share #11 Posted July 21, 2017 Jesse, I assume this means you use a two second timer to give you that amount of time to brace/stabilize? Good suggestion. David Yes. I am in Iceland, and will try to post an example when I return. Jesse Sent from my GT-I8190 using Tapatalk Link to post Share on other sites More sharing options...
jip Posted July 29, 2017 Share #12 Posted July 29, 2017 The 006 has a linear iso gain... meaning: Shooting 1/125 ISO 100 F2.5 pushing 4 stops in Lightroom. has the same effect as Shooting 1/125 ISO 1600 F2.5 not pushing at all in Lightroom. Just don't forget that Lightroom increases noise reduction automatically for S006 files when higher ISO's are set, if you match these settings there is literally no difference between the two files. Unlike the Leica M8/M9 that are better shot at ISO 160 and then pushed in Lightroom, the S006 files pushing in camera or in post production have the exact same effect. Link to post Share on other sites More sharing options...
djmay Posted July 30, 2017 Share #13 Posted July 30, 2017 Yes. I am in Iceland, and will try to post an example when I return. Jesse Sent from my GT-I8190 using Tapatalk S 006, 30mm ISO 400, 1/30 second exposure Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/274632-low-light-shooting-techniques/?do=findComment&comment=3326477'>More sharing options...
