jmoto Posted July 1, 2017 Share #1 Posted July 1, 2017 Advertisement (gone after registration) Hi fellow Q owners, I have noticed that on my Q there is slight wiggle to the front of the lens. I can actually feel the front housing around the glass moving ever so slightly if I physically move it back and forth. This is more annoying than anything else as I can feel it while holding the camera and using it. This is not the same as the IS movement that I can feel/hear when the Q is off and goes away when the camera is turned on. Does anyone else have this slight wiggle? Link to post Share on other sites More sharing options...
Advertisement Posted July 1, 2017 Posted July 1, 2017 Hi jmoto, Take a look here Front of the lens wiggle? . I'm sure you'll find what you were looking for!
Leica Guy Posted July 1, 2017 Share #2 Posted July 1, 2017 Hi fellow Q owners, I have noticed that on my Q there is slight wiggle to the front of the lens. I can actually feel the front housing around the glass moving ever so slightly if I physically move it back and forth. This is more annoying than anything else as I can feel it while holding the camera and using it. This is not the same as the IS movement that I can feel/hear when the Q is off and goes away when the camera is turned on. Does anyone else have this slight wiggle? I don't feel any wiggle. Bummer. Probably should get it checked. I've not heard of this problem before. Good luck. Link to post Share on other sites More sharing options...
odds Posted July 1, 2017 Share #3 Posted July 1, 2017 ...Does anyone else have this slight wiggle? Absolutely not. The lens sits tight on my Q. There is a small play in the aperture ring. Link to post Share on other sites More sharing options...
