Guest Posted June 16, 2017 Share #1 Posted June 16, 2017 (edited) Advertisement (gone after registration) Hello, the title says it all. Do the focusing helicoids/helicals, whatever the correct term is, those inner tubes that go into the outer tubes on the lens turret of a Focomat IIa (with 5cm/9,5cm lenses) fit the late Focomat IIc? I'm not looking for AF-compatibility here, just the mechanical compatibility of the threads of the tubes. And while we're at it. As I understand the early IIc where shipped with 5/9,5cm lenses as well. Do those helicoids fit the later 90/100mm ones? Again, I'm looking for mechanical compatibility of the inner tubes only - not AF compatibility. Thanks alot Andi Edited June 16, 2017 by Guest Link to post Share on other sites More sharing options...
Advertisement Posted June 16, 2017 Posted June 16, 2017 Hi Guest, Take a look here Focomat IIa helicoids - do they fit into a late IIc? . I'm sure you'll find what you were looking for!
Guest Posted July 6, 2017 Share #2 Posted July 6, 2017 Again, replying to myself answering some things. Thanks to M.Hilo I got hold of some older helicoids that might (or might not) belong to a IIa or an early 2c (with 50/95mm lenses). We're not sure. Those inner tubes are about 2cm shorter than my late IIc helicoids. But, they fit the late IIc 60mm-lens tube. I wasn't able to fit them into the 100mm slot. In theory both are the same, so it should work and maybe it was just my two left hands. Link to post Share on other sites More sharing options...
plus4dbu Posted February 25, 2019 Share #3 Posted February 25, 2019 On 7/6/2017 at 8:02 AM, Guest said: Again, replying to myself answering some things. Thanks to M.Hilo I got hold of some older helicoids that might (or might not) belong to a IIa or an early 2c (with 50/95mm lenses). We're not sure. Those inner tubes are about 2cm shorter than my late IIc helicoids. But, they fit the late IIc 60mm-lens tube. I wasn't able to fit them into the 100mm slot. In theory both are the same, so it should work and maybe it was just my two left hands. I'm searching for inner helicoids as well and came across this thread. I have a IIc but missing 95mm inner helicoid. I tried fitting helicoid presumably from an earlier IIa, it does not fit 95mm side but fits 60mm tube. Any luck finding helicoid for your IIc? Link to post Share on other sites More sharing options...
