Reflections Posted May 11, 2017 Share #1 Â Posted May 11, 2017 Advertisement (gone after registration) Hi, Â I just took the plunge to purchase both 24-90mm and 90-280mm. I received both of them 2 days ago. The 90-280mm works very well however the 24-90mm lens seems to have some problems. The OIS seems to be keep activating and causing the image to jerk although I didn't do anything to the camera. When I switch off the OIS, everything went back to normal. I took a video of the jerking and the noise (physical sound) that the lens make. My SL is mounted onto a Tripod and 24-90mm lens is at 90mm focusing on the ironman, the video is in this link... Â https://www.flickr.com/gp/130958979@N06/Yj0Ws6 Â Hope someone can share with me if there is any setting that I have set wrongly or this is just a bad copy. Thank you very much! Â regards Wang Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2017 Posted May 11, 2017 Hi Reflections, Take a look here 24-90mm OIS Noise - Normal?. I'm sure you'll find what you were looking for!
LocalHero1953 Posted May 11, 2017 Share #2 Â Posted May 11, 2017 IS doesn't work well on a tripod - it's not intended for that purpose, and can cause problems. Switching off OIS is the right thing to do here. Do you have the same problem handheld? Â If I sound authoritative, it is because I had exactly the same problem with the same system when I got it, and discovered my mistake by online research afterwards. Link to post Share on other sites More sharing options...
thighslapper Posted May 11, 2017 Share #3  Posted May 11, 2017 The behaviour could be explained as Paul says ...... but the sound is odd ..... both AF and OIS on the 24-90 is inaudible unless you put your ear close to the lens.  OIS on when using tripod/static camera tends to result in the image drifting a bit ..... but it tends to be slow and not a sudden jerk.  I have OIS on all the time .... even with tripod use and have never seen anything like this ..... I would be inclined to suspect a lens fault or something wrong with the lens firmware. 1 Link to post Share on other sites More sharing options...
Reflections Posted May 11, 2017 Author Share #4 Â Posted May 11, 2017 IS doesn't work well on a tripod - it's not intended for that purpose, and can cause problems. Switching off OIS is the right thing to do here. Do you have the same problem handheld? Â If I sound authoritative, it is because I had exactly the same problem with the same system when I got it, and discovered my mistake by online research afterwards. Hi Paul, the same happened when handheld. 1 Link to post Share on other sites More sharing options...
Reflections Posted May 11, 2017 Author Share #5  Posted May 11, 2017 The behaviour could be explained as Paul says ...... but the sound is odd ..... both AF and OIS on the 24-90 is inaudible unless you put your ear close to the lens.  OIS on when using tripod/static camera tends to result in the image drifting a bit ..... but it tends to be slow and not a sudden jerk.  I have OIS on all the time .... even with tripod use and have never seen anything like this ..... I would be inclined to suspect a lens fault or something wrong with the lens firmware.  Thank you, I probably arrange for it to be send back for repair. Link to post Share on other sites More sharing options...
Jeff S Posted May 11, 2017 Share #6 Â Posted May 11, 2017 Repair? I'd ask for an exchange, presuming this was from a reputable dealer. Â Jeff Link to post Share on other sites More sharing options...
Reflections Posted May 12, 2017 Author Share #7 Â Posted May 12, 2017 Advertisement (gone after registration) Repair? I'd ask for an exchange, presuming this was from a reputable dealer. Â Jeff You are right, that's what I will be doing. Thank you. Link to post Share on other sites More sharing options...
Joshua Lowe Posted May 12, 2017 Share #8 Â Posted May 12, 2017 You can hear a faint "hiss" from what I believe are the OIS motors and you might hear a slight noise when powering the camera on, but I've never seen any kind of jerking movement in the image. Â I've used a few different 24-90s so I'm pretty confident what you're experiencing isn't normal. Link to post Share on other sites More sharing options...
flyboy Posted May 13, 2017 Share #9 Â Posted May 13, 2017 I only hear a light noise of OIS when environment ist almost noiseless and my ears is really close to the lens. So, I think your noise is a fault. Link to post Share on other sites More sharing options...
Reflections Posted May 13, 2017 Author Share #10 Â Posted May 13, 2017 Thank you both. Yes, spoken to the dealer and will get it replace. 2 Link to post Share on other sites More sharing options...
northernlights Posted May 31, 2020 Share #11  Posted May 31, 2020 Hi Wang, Can I check if the jerking is an issue? Didn’t hear a follow up. I saw your video and noticed a 24-90 used i tested yesterday had the same jerking. I did not pan. It just jerked exactly like your video showed. I was going to buy used from the guy who was selling when i was prompted to double check first. Link to post Share on other sites More sharing options...
