Shootist Posted June 21, 2007 Share #1 Posted June 21, 2007 Advertisement (gone after registration) I just receive this lens yesterday and like it a lot. One problem I am having is coding of it. I marked the black lines on the mount for the 21 ASPH and because of a screw it showed up as a 28, the screw is being seen as a black line. So I used some white lacquer to fill in the screw head and then it shows up as the 21. But the sharpie marks wear off with one mount, dismount of the lens. I then figured I'd dremmel the spots where the black goes. This went find except that on one of my M8 I now get no reading for the lens and on the other it works fine. On the body that doesn't read this lens it does read all other lenses I have, all factory coded all Leica. Anybody got any tips to making it work on both bodies? Link to post Share on other sites More sharing options...
Advertisement Posted June 21, 2007 Posted June 21, 2007 Hi Shootist, Take a look here CV 21 Color Skopar-P. I'm sure you'll find what you were looking for!
Joe Mondello Posted June 21, 2007 Share #2 Posted June 21, 2007 Is this the new M-mount version of the lens? If it is the LTM, get the Milich adapter for it. Link to post Share on other sites More sharing options...
sean_reid Posted June 21, 2007 Share #3 Posted June 21, 2007 I just receive this lens yesterday and like it a lot. One problem I am having is coding of it.I marked the black lines on the mount for the 21 ASPH and because of a screw it showed up as a 28, the screw is being seen as a black line. So I used some white lacquer to fill in the screw head and then it shows up as the 21. But the sharpie marks wear off with one mount, dismount of the lens. I then figured I'd dremmel the spots where the black goes. This went find except that on one of my M8 I now get no reading for the lens and on the other it works fine. On the body that doesn't read this lens it does read all other lenses I have, all factory coded all Leica. Anybody got any tips to making it work on both bodies? Using the Sharpie method will mean that the marks always rub off. I'd pull the bayonet and send it to John to be milled. Cheers, Sean Link to post Share on other sites More sharing options...
Shootist Posted June 21, 2007 Author Share #4 Posted June 21, 2007 Is this the new M-mount version of the lens? If it is the LTM, get the Milich adapter for it. New M mount. Link to post Share on other sites More sharing options...
Shootist Posted June 21, 2007 Author Share #5 Posted June 21, 2007 Using the Sharpie method will mean that the marks always rub off. I'd pull the bayonet and send it to John to be milled. Cheers, Sean That may be the deal. Link to post Share on other sites More sharing options...
sean_reid Posted June 21, 2007 Share #6 Posted June 21, 2007 That may be the deal. Thats exactly what I would do if it were my lens. Cheers, Sean Link to post Share on other sites More sharing options...
