Hdr?
fordfanjpn
Although I messed around with this a little with the D200, I was wondering if anyone here has tried doing HDR with M8 files. I did do a quick search but didn't really find anything. It would seem that with the amount of information contained in the M8 files, it should be possible to do some amazing things with HDR. Has anyone tried it, and if so, could you post the result? Thanks.
Bill
x
  • Replies 41
  • Created
  • Last Reply
I have done some. it's very possible to do HDR even from one digital negative even.
Here's an example from forum member Joi Ito:
And here is the single DNG he used to get there:
I have more examples I'll look for tomorrow.
Thanks. I'd love to see those in a larger size, but even in the small jpegs you can see the potential. I'll look forward to seeing more.
Bill
Im totally lost. Spose it depends on what bits important. How come he didnt bring up the lefths and darken the right? You want to see the ceiling grid?
Interested in HDR what is it?
Haaaalp:eek:. I lost me chocky bickie into the fridge when I was loading up this stuff. It says Bavaria Holland? Anyone know what is this cra.....
Needs some HDA
Ehhh HDR? Wheres Jaap, he'd know.
Tripod...HDR...Mmmm...two presses of th digit or time on the computer:rolleyes: Get it right or fix it later:rolleyes: Snakes and ladders...hmmmm
Hey Im, this bavaria is real garbage. Wonder if I can take the rest back.
You know the story about the boy who was pissing in the canal and saw the hole in the dyke?...Well they bottled it. No not the north sea the other stuff!
the best way to do a HDR image is to do it right with two exposures from a tripod
blending two different developed files does not produce as pleasing results, but sometimes this can prove helpful
here is one that I blended from an M8 DNG dual converted to get the sky and shadow details in the alley the way I wanted them
I did not have a tripod & the need for wider DR was not appreciate until post capture
(I put this up at the risk of it being critiqued as a "pig," a risk I will take in the interest of maybe furthering everyone's knowledge:) ) ...a larger version and shooting information can be found here
Leica M8 photographs Photo Gallery by Artichoke Vinagrette at pbase.com
I think dual conversions work best when the effects are subtle ...taking two exposures is clearly the better way of doing this, but sometimes the dual conversion technique can prove useful to pull out a bit extra from the files ...the M8's shadow recovery is good enough to allow considerable play before breaking up
Photomatix is an outstanding bit of software to make this process simpler ...the quality of the files produced is excellent & it offers up an almost bewildering number of options to do this ...btw they strongly recommend using dual exposures to get HDR images
anyone interested in HDR should give this software a trial
here is a link
Download HDR photo software Photomatix
How would you use one DNG file in HDR? Produce multiple files with progressive adjustment exposure settings from the base DNG file?
HDR capabilities is something we should be petitioning Solms to provide in the M8b. Or, even better yet, in a new M8 firmware update. Hell, even exposure bracketing would be nice.
here is a link
I haven't looked at this Photomatix software. I note that PhotoShop CS3 has HDR capability, although I have not tried it yet. Artichoke, have you tried the PS? If so, do wish to draw any comparisons?
BTW, your posted image looks more like HOWston than HEWston.
Right, exactly. IMHO, HDR is a very precious technique, and I'm sort of tired of seeing the crazy wide range images that some folks use it for. So, with one DNG negative, you can keep the midtones and highlights, or boost them a bit, and then do another version with a bunch of shadow detail, for example, and use those as the basis of your HDR. I guess it's not "true" HDR without multiple exposures, but whatever.
Bracketing would make the process a lot easier and indeed it's the only way to get truly high dynamic range. But I don't really want more features on the M8 ;)
Otherwise, you're talking tripod and manual adjustment, which is fine so long as you don't have a moving subject, or if you have software that adjusts or patches.
Although the M8 is designed along purist lines, I agree that the current exclusion of exposure bracketing is a great suprise and a real shame.
Beside SDHC support, the other main feature I would like to see implemented through the next M8 firmware update would be support for shutter bracketing.
This would be a very practical and non-gimmickry addition for a lot of people.
Geoff
myspace.com/geoffotos
Most of the HDR shots I've seen seem unreal, somehow -- maybe because my eyes have been trained too long on photos with LDR (Limited Dynamic Range.) I very much like the shot by Artichoke, but the fact that a blue sky and wispy white clouds are visible as well as the detail in the dark alley shadows, is right on the edge of being disturbing. So I think the technique has to be used carefully, or it looks pasted-together. Maybe things will change as our eyes get more used to HDR photography.
With the fire-truck shot, I think HDR actually detracts from the image; you want to see pipes? The darkness around the fire truck pulls your eye to the main subject.
