Wayne Posted March 21, 2017 Share #1 Posted March 21, 2017 Advertisement (gone after registration) Camera was IIIA; lens was LTM 50mm Summicron; film was Lomo 100; C41 Kit was Unicolor (Powder.) Processing was accomplished in JOBO rotary processor. Scan was made using PrimeFilm 7200. While my advance in color processing has been slow, it has been steady.....Then this roll. I am curious if any of those in the "Know" have seen this before and are able to help me figure out what went wrong. There are some dust inclusions, but the vast majority of the galaxy of white spots are not related to dust. The problem is present in the entire roll, affecting all shots equally. This one illustrates the problem best. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/270582-analysis-and-advice-needed/?do=findComment&comment=3238494'>More sharing options...
Advertisement Posted March 21, 2017 Posted March 21, 2017 Hi Wayne, Take a look here Analysis and advice needed.. I'm sure you'll find what you were looking for!
pico Posted March 21, 2017 Share #2 Posted March 21, 2017 The texture and noise suggests reticulation. The white spots might be due to incomplete solution (mixing) of the chemistry. . Link to post Share on other sites More sharing options...
fotomas Posted March 21, 2017 Share #3 Posted March 21, 2017 Hard to tell from distance. I have a similar problem with some old Fuji Reala films, the expired about 2008 and stay well cooled in the fridge for years. Since the colours are quite exceptable they develop a lot of small deposits on the backside that showed up as white spots. Fortunately you can carefully wash them away with alcohol. Other films, developed in the same run didn't show this effect. I don't know the reason for this and if this might be the same here, but if you wipe it off you got a clean negative. If I look on the reflection of a window for example on the backside of the film I can see that there are deposits. To remove it I place the film backside up on a cleaned glass plate. Than I moisten a hanker-chief with a drop of alcohol and move it once or twice in one direction over the film. Never rub on the side of the layer! And don't let the layer get wet. But of course there might be other reasons for that also. Link to post Share on other sites More sharing options...
gbealnz Posted March 21, 2017 Share #4 Posted March 21, 2017 Can't help with colour diagnosis, I am too scared to even try it, so take my hat off to you (and rpavich as well). I did get a roll of shocking spots a while back, in my case it was old sedimented fixer, which I promptly but too lately, threw out. B&W film of some description, but old Agifix. Since mixing new fix, no problem. Could this be the problem you have? Like fotomas says, hard to tell from this sample. Would your entire temperatures be close to each other, so as to dispel the reticulation theory Pico suggests? Gary Link to post Share on other sites More sharing options...
fotomas Posted March 21, 2017 Share #5 Posted March 21, 2017 Now, back home I searched for an example of what I mean. Looks a bit different, so I guess it must be something else. Not well solved chemicals maybe or limescale from hard water... Here the example from my Reala trouble: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/270582-analysis-and-advice-needed/?do=findComment&comment=3238842'>More sharing options...
gbealnz Posted March 21, 2017 Share #6 Posted March 21, 2017 Now, back home I searched for an example of what I mean. Looks a bit different, so I guess it must be something else. Not well solved chemicals maybe or limescale from hard water... Here the example from my Reala trouble: Hmmmm, can't help you with this then, my snotty fixer issue was spots, not streaks. I have had a slightly less noticeable version of this from local commercial development, which I put down to less than clean rollers, in the processing machine. I hark back to the dip and dunk days, where this wasn't usually an issue. Good luck. Gary Link to post Share on other sites More sharing options...
fotomas Posted March 21, 2017 Share #7 Posted March 21, 2017 Advertisement (gone after registration) Thank you Gary,Luckily I have a solution for this problem, as described above. It must be something with this type of film, since only Reala's are affected, even if developed together with others.Just post the image, for comparison with the issue of the TO to proof if it might be the same problem. Regards Frank Link to post Share on other sites More sharing options...
Doc Henry Posted April 10, 2017 Share #8 Posted April 10, 2017 Fotomas partial reason : film out of date ? another questions : it happens on the entire roll or only on some pictures ? Try another roll of color Fuji To answer Wayne , I also dev myself color film (Kodak Portra 160 and 400) but in "manual" tank Paterson and I never have this problem you are. Have you this also in b&w and do you use the same tank processor ? Color looks fine in your picture.Have you these little spots on all the roll ? may be try another roll to see. Temperature and agitation correct ? another questions : rev and fix new or used ? If used , how many rolls you dev. for 1 liter ? . Normaly if high Isos (400) , the rev. is quickly used ! not the case if it's low Isos (160) Rg Henry Link to post Share on other sites More sharing options...
Wayne Posted April 15, 2017 Author Share #9 Posted April 15, 2017 I did have the problem throughout the roll. Although I was confident the chemistry should not have expired- either by time or use- I went ahead and mixed another batch of C-41 chemicals. Have not had a repeat of the problem. In this, i.e new, instance of mixing chemistry I used distilled water for purpose of mixing stablizer. Additionally, and for the first time, mixed developer and Blix at elevated temperature. I seem to be getting better results now. Thanks again for attention and comments. Link to post Share on other sites More sharing options...
