leica1215 Posted February 18, 2017 Share #1 Posted February 18, 2017 Advertisement (gone after registration) My sl charger lately happen few times that when put battery on charge few hours later when check the level found that both charging light and 80% light keep on blinking, so I have to unplug the charger and charge again, anyone experience this? Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Advertisement Posted February 18, 2017 Posted February 18, 2017 Hi leica1215, Take a look here SL charger both light keep blinking? . I'm sure you'll find what you were looking for!
Joshua Lowe Posted February 18, 2017 Share #2 Posted February 18, 2017 Battery error. Have you tried with a different battery? Link to post Share on other sites More sharing options...
leica1215 Posted February 19, 2017 Author Share #3 Posted February 19, 2017 Not yet, if it stop charging I might get new battery, but so far my battery works ok ... thanks Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
ramarren Posted February 19, 2017 Share #4 Posted February 19, 2017 Well, it's either a fault in the charger or the battery. If the battery is continuing to work well, I'd order a spare charger (so you don't get caught without) and see if the same battery in that charger has the same issue. If it doesn't, get Leica warranty work on the faulty charger. If it does, try another battery in that charger to be sure the charger isn't at fault and then get Leica warranty work on the battery. It's always good to have a spare charger anyway, just like it's always good to have a spare battery. Link to post Share on other sites More sharing options...
J S H Posted February 20, 2017 Share #5 Posted February 20, 2017 I have seen this behavior when my batteries were newer. In my case, I discharged the battery to near empty through normal use of the camera and then recharged. Since that time they have been fine. Link to post Share on other sites More sharing options...
