Leica Q 21 mm, Rico GW3
tgm
A discussion on using the Rico GW3 converter triggered by the thread on Leica rumors
http://leicarumors.com/2017/02/02/you-can-use-the-ricoh-gw-3-21mm-wide-angle-conversion-lens-on-the-leica-q-camera.aspx/
started in ther german forum.
http://www.l-camera-forum.com/topic/269165-q-mit-21mm-ricoh-gw-3/
Here are some primliminary picuters at f/11, 400 ASA
full picture
100 % crop center
100 % outer part
x
100 % crop border
so what about the image quality, is it ok?
My impression, very important, autofocus and even manual focus does not work, you need to set the distance manually using the scale
best regards
Thomas
Looks quite efficient indeed. From the DNG one may find another setup for the barrel correction that even better solves the (slight) corner deformation.
Now, what I'd like to see is rather a teleconverter, but optically I fear it's almost not possible (or it would look like my current setup: an enormous bird-watching scope attached to the camera ;-)
H.
The output looks very decent. Do you have any concerns about the weight of the adapter on the end of the lens i.e. could it damage the autofocus motor or anything like that?
Would love to see more shots if you have them. :) I just ordered a Q and am wondering if I should get this adapter too since I also enjoy shooting at 21mm.
You can find more pictures on the German part
http://www.l-camera-forum.com/topic/269165-q-mit-21mm-ricoh-gw-3/page-3?do=findComment&comment=3214778
page 3
best regards
Thomas
