marknorton Posted June 16, 2007 Author Share #21 Â Posted June 16, 2007 Advertisement (gone after registration) Well, no one would call that bag effete :-) Â Steve's picture above shows the bag well. If you remove the DSLR partitioning, the Lowepro Traveller (2 M bodies, 6-8 lenses) and a pair of Duovids fit in the front space; that laptop slot is 14 inches wide, so a 15" MacBook Pro will fit perfectly. Â Works for me... Link to post Share on other sites More sharing options...
Advertisement Posted June 16, 2007 Posted June 16, 2007 Hi marknorton, Take a look here Bag Problem - Solved. I'm sure you'll find what you were looking for!
jrc Posted June 16, 2007 Share #22 Â Posted June 16, 2007 A question for those from the UK -- if you're told you can't board because you have two bags, or your bags are too heavy or too big, what do they do if you agree, and decide to walk away? In the US, planes won't fly with unaccompanied checked baggage (or at least they wouldn't a couple of years ago.) If somebody backs off a flight at the last minute, they have to unload the flight and pull the bags... Â I'm curious about what would happen if you pushed back a bit, by simply walking away. Would they have cause for some kind of legal action? Or don't the same rules apply? Â JC Link to post Share on other sites More sharing options...
marknorton Posted June 16, 2007 Author Share #23 Â Posted June 16, 2007 I can't imagine a flight taking off with unaccompanied baggage, so they would most likely pull the bags off, then make sure they run over them with the tractor... Link to post Share on other sites More sharing options...
carstenw Posted June 16, 2007 Share #24  Posted June 16, 2007 Well, thanks for the heads up that other people 'are' having problems. It's worth knowing. Another reason to travel with M8s and not DSLRs  I will echo the problems others have seen. I once had to argue with an attendant that my bag was not too large, and this *after* I showed her that it fit in their device. She almost didn't allow it but I didn't back down, and eventually was let through. Link to post Share on other sites More sharing options...
carstenw Posted June 16, 2007 Share #25 Â Posted June 16, 2007 One note: most flight companies allow one bag *plus* whatever you carry in your pockets and a camera around the neck, so I often stick a lens in each jacket pocket and the camera around my neck to make sure I have no weight problems. Link to post Share on other sites More sharing options...
DaveEP Posted June 16, 2007 Share #26  Posted June 16, 2007 A question for those from the UK -- if you're told you can't board because you have two bags, or your bags are too heavy or too big, what do they do if you agree, and decide to walk away? In the US, planes won't fly with unaccompanied checked baggage (or at least they wouldn't a couple of years ago.) If somebody backs off a flight at the last minute, they have to unload the flight and pull the bags... I'm curious about what would happen if you pushed back a bit, by simply walking away. Would they have cause for some kind of legal action? Or don't the same rules apply?  JC  They delay the flight and take your checked luggage off. Link to post Share on other sites More sharing options...
