jackal Posted June 13, 2007 Share #1  Posted June 13, 2007 Advertisement (gone after registration) are the developer settings (that i can copy and paste around in Bridge) saved with the tif file ?   is there any way to make librarys of these settings in any way ... sort of like favourites or templates ?  thanks  R Link to post Share on other sites More sharing options...
Advertisement Posted June 13, 2007 Posted June 13, 2007 Hi jackal, Take a look here CS3 develop settings. I'm sure you'll find what you were looking for!
Shootist Posted June 14, 2007 Share #2  Posted June 14, 2007 are the developer settings (that i can copy and paste around in Bridge) saved with the tif file ?  is there any way to make librarys of these settings in any way ... sort of like favourites or templates ?  thanks  R  Do you mean the adjustments you make in ACR to the DNG file? If so then yes you can save them. when you have ACR open and you have made adjustments to a image go to the little menu icon in the upper right hand of the adjustment section, just below the icons for basic/Tonal Curve/Detail/what have you, in the bar that has the name of the adjustments settings you are using on the right and click on it. Near the bottom of the list that pops up is Save Settings. Save it with a name you cna remember and then you go back to the drop down list and select Load settings then next time you want to use that group of settings. Link to post Share on other sites More sharing options...
