M4-P Serial number doesn't match database. Please help!
Hi all!
I have been offered a Leica M4-P for what I think is a good price.
However, I have been sent a picture and the serial number of the camera is 1532XXX.
The databases I have checked show it should be a M4-2, yet it is quite clearly an M4-P!
Can anyone shed any light on this?
Thanks in advance!
Regards
Carl
The wiki lists one M4-2, s/n 1532885 as an M4-P, so there was likely a batch of -Ps around that time. It was during the changeover from the -2 to the -P and serial numbers are pre-assigned and not necessarily sequential. I'd say it's an early M4-P.
Why would someone try to pass off an M4-2 as an M4-P? They're worth a similar amount and have obviously different viewfinders, the rouse would be short lived and not profitable.
Thanks for that. Are the earlier ones worse or better than the later ones? I know they modify things as they go along!
Regards
Carl
Regards
Carl
Welcome to Leica-land.
Are earlier ones better or worse? Depends on how you define "better", "worse", and who you ask  :)
Typically, things were modified as production went on. Hardly ever documented, and sometimes for an improvement for the user, and sometimes for an improvement in Leica's bottom line.
  • 4 weeks later...
