lemalk Posted June 13, 2007 Share #21 Â Posted June 13, 2007 Advertisement (gone after registration) Dugby - If the build quality on the D3 and the D-Lux 3 is any indication, then YES, I agree that Panny should've built the M8...so they could offer a Panasonic version for 25% less... Â That. Would. Be. Sweet. Link to post Share on other sites More sharing options...
spylaw4 Posted June 13, 2007 Share #22 Â Posted June 13, 2007 Dugby - If the build quality on the D3 and the D-Lux 3 is any indication, then YES, I agree that Panny should've built the M8...so they could offer a Panasonic version for 25% less... Â That. Would. Be. Sweet. Â So what about building the M9/R10? Link to post Share on other sites More sharing options...
karlitos Posted June 13, 2007 Share #23 Â Posted June 13, 2007 The L1 has the following extra features (Firmware V2.0) that the D3 currently does not have:Â <http://panasonic.jp/support/global/cs/dsc/download/L1K/> Â 1. Added a multiple exposure function. Â 2. Added "panning mode"(MODE3) to the optical image stabilizer. Â 3. Added a "low-angle" viewing mode that makes it easier to view the LCD display when the camera is held below eye level. Â 4. Added feature that simplifies setting the aperture when using a lens without an aperture ring. Â 5. Added two manual white balance settings to GUI. GUI design uses navigational cursor to easily select, and set, white balance (WB) to change the color temperature, or set the ISO sensitivity or flash. Time restriction for making changes was removed. Â 6. Added "HOLD" option to Auto Review time, enabling continuous viewing. Â 7. Added feature to allow zoomed playback of photos. It's now possible to move back to the preceding images or forward to the next images while the image is still zoomed. Â 8. Added [AUTO] for the ISO sensitivity in the aperture-priority AE mode [A] and shutter speed-priority AE mode . Â 9. Added GUI option to easily check the firmware version. Â 10. Improved the performance of AE(Auto Exposure) and AWB(Auto White Balance). Â FYI, Digilux 3 firmware update will be available from Leicas website by the end of the month. Â Karlitos. Link to post Share on other sites More sharing options...
