Check Battery
borowiec
I have a loaner M 240 while mine is in Germany for repairs (due to failing shutter, as I posted in early June). I haven't used the loaner in several weeks, as I bought a Sony A7IIR when my M stopped working. However, I need to use the loaner M now and, when I turn it on and press the Info button, I get a message in red saying Check Battery (I see that there are many posts about a Check Battery Life message, but that's not what mine says so I'm not sure if it's the same thing). Also, the camera displays that message regardless of which battery is in the camera: the one provided with the loaner or the two from my own M. The batteries all seem to charge properly, and to hold charge.
What should I do?
Thank you! It hadn't occurred to me to check the firmware version—I assumed that it would have the latest, as it came from Leica, but it had 2.0.0.12. Anyway, I've installed the newest firmware and the message is gone :) .
