Guest NEIL-D-WILLIAMS Posted August 31, 2016 Share #1 Posted August 31, 2016 Advertisement (gone after registration) Yesterday I bent and damaged my Leica S-007 weathering cable, is there an option to use the USB socket instead of paying another 400 bucks for my stupid mistake yesterday?? Link to post Share on other sites More sharing options...
Advertisement Posted August 31, 2016 Posted August 31, 2016 Hi Guest NEIL-D-WILLIAMS, Take a look here leica s typ 007 tethering cable . I'm sure you'll find what you were looking for!
hoppyman Posted August 31, 2016 Share #2 Posted August 31, 2016 I don't think so, since there is no other USB connection to the body than the LEMO one. It's interesting, perhaps reflecting design time frame that connection uses the USB 2.0 standard whereas the SL uses USB 3.0 which is much better when tethering. That may be a requirement with the much higher frame rates with the SL of course. Link to post Share on other sites More sharing options...
eprom Posted August 31, 2016 Share #3 Posted August 31, 2016 006 and 007 require different USB LEMO-cables. I think the cable for the 007 is USB 3.0. SL with LEMO would be cool - I like that system of connection. Link to post Share on other sites More sharing options...
jip Posted September 6, 2016 Share #4 Posted September 6, 2016 S2 S006 are USB2 LEMO connection, S007 is USB 3 LEMO connection. To answer your question, NO you cannot use a normal USB connection, since the S007 does NOT have a normal USB connector. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 8, 2016 Share #5 Posted September 8, 2016 Ive got a replacement coming back with my S30mm lens that is in for a MOT Link to post Share on other sites More sharing options...
hoppyman Posted September 9, 2016 Share #6 Posted September 9, 2016 Jip and eprom. The instruction book for my S (Typ 007) says "4 pin LEMO socket for data output (USB 2.0 standard)" Of course the cable does work when connected to USB 3.0 socket on my computers. I have never owned the S (Typ 006) I don't know what cable or standard is used there.My SL instruction book says"Micro B USB port (3.0 High Speed) and that camera really needs that faster data throughput when tethering (and its firmware 2.1 includes an update to improve performance there) Link to post Share on other sites More sharing options...
