Giulio Zanni Posted August 5, 2016 Share #1 Posted August 5, 2016 Advertisement (gone after registration) I bought a Leica adapter to use some R lenses on the M but the tripod foot does not rotate. I am thinking about using an arca swiss type L plate attached to the adapter in order to move from horizontal to vertical with some heavier lenses. If anybody is suing this set-up I would be interesting in knowing which L plate is used. Thanks, Giulio Link to post Share on other sites More sharing options...
Advertisement Posted August 5, 2016 Posted August 5, 2016 Hi Giulio Zanni, Take a look here L plate for M R adapter. I'm sure you'll find what you were looking for!
mmradman Posted September 26, 2016 Share #2 Posted September 26, 2016 I bought a Leica adapter to use some R lenses on the M but the tripod foot does not rotate. I am thinking about using an arca swiss type L plate attached to the adapter in order to move from horizontal to vertical with some heavier lenses. If anybody is suing this set-up I would be interesting in knowing which L plate is used. Thanks, Giulio Just bumped into this thread. It is a good question. M-R adaptor foot comes with a hole for a locking pin but nearest Arca-Swiss [A-S] plate with a pin is from Novoflex but the fit is somewhat loose. I use small A-S plate(don't recall the brand), about 35x40mm in size. Plate has a lip on the upper side which rests against the front of the adaptor foot and; (a) prevents rotation & ( keeps plate squared with the foot. As for "L" plate Arca-Swiss makes wonderful universal plate but it is better suited to be attached to a camera and it works better with lighter lens. Have you considered flipping ball head to provide you with Landscape=Portrait change of orientation. Any heavy lens may cause slip between the plate and adaptor foot, it is only a single screw keeping everything in place. Link to post Share on other sites More sharing options...
Giulio Zanni Posted September 26, 2016 Author Share #3 Posted September 26, 2016 Just bumped into this thread. It is a good question. M-R adaptor foot comes with a hole for a locking pin but nearest Arca-Swiss [A-S] plate with a pin is from Novoflex but the fit is somewhat loose. I use small A-S plate(don't recall the brand), about 35x40mm in size. Plate has a lip on the upper side which rests against the front of the adaptor foot and; (a) prevents rotation & ( keeps plate squared with the foot. As for "L" plate Arca-Swiss makes wonderful universal plate but it is better suited to be attached to a camera and it works better with lighter lens. Have you considered flipping ball head to provide you with Landscape=Portrait change of orientation. Any heavy lens may cause slip between the plate and adaptor foot, it is only a single screw keeping everything in place. Thanks, yes this is also what I did in the end, to go with a simple small plate, however flipping the ball head when using the 80-200 is far from convenient. Link to post Share on other sites More sharing options...
