Lost SL charger
Lenter
Hi , can anyone help me with the following problem . I'm in N Korea , I have an SL with three batteries but lost my charger. Does anyone know of any way to charge the battery packs with , for example, an adapter of another electrical device? If that could then what should be the capacity of the charger. I imagine that I have the two wires on the plus and minus of the battery slice . I 'm not in the gekegenheid they all find out .
Merci Erdna
Lithium-Ion batteries don't take kindly to charging voltage that is not properly regulated, so whatever you use to charge your batteries has to have a proper charging circuit in it. In other threads, a couple of chargers have been suggested for travel purposes, like the Hähnel Unipal Plus" but i suspect you're going to have nearly as much trouble getting one of those as you would getting a Leica charger.
Tough spot, sorry to say.
