halo Posted August 4, 2016 Share #1 Posted August 4, 2016 Advertisement (gone after registration) Kipon Baveyes introduces a series of three of the world’s first lens adapters that bring the famous medium format Hasselblad V mount optics to Sony A7, Leica SL and Leica M 35mm full frame cameras, virtually eliminating any crop factor image loss and maintaining diagonal angle of view. Your favorite outstanding Carl Zeiss lenses, from wide angle to telephoto, ingeniously compress to a full-frame image, performing just like they were 35mm format full frame optics. The transformation results in a 0.7x factor to the original lens focal length with a gain of one stop in lens speed. Foremost in the advanced adapters, is the custom designed five element multicoated formula by German optics research institution IB/E OPTICS, with the ability to use full frame SLR lenses on crop sensor camera bodies and mirrorless cameras. The Baveyes tele-centric formula is exclusively designed by IB/E Optics in Germany to only the utmost precision and quality. Hasselblad lenses by Carl Zeiss are legendary for contrast, flare resistance, color saturation, bokeh and are in a class of their own compared to even the best 35mm format glass. And the Sony and Leica image sensors, in the heart of their robust camera bodies, give new life to the Hasselblad/Zeiss heritage. Auch eine Version für Leica M verfügbar! Habe einen KIPON-Adapter Leica M auf Sony E, der sehr gut verarbeitet ist und auch das Auflagemaß perfekt hält. Link to post Share on other sites More sharing options...
Advertisement Posted August 4, 2016 Posted August 4, 2016 Hi halo, Take a look here Neuer Adapter für Hasselbl. V mit Erhalt es ursprünglichen Bildwinkels . I'm sure you'll find what you were looking for!
poseidon Posted August 4, 2016 Share #2 Posted August 4, 2016 Hi, was die Optik darin aus den Bildern macht, müsste man abwarten............. Gruß Horst Link to post Share on other sites More sharing options...
Guest digiuser_re-reloaded Posted August 4, 2016 Share #3 Posted August 4, 2016 Super das, da hat man die besten Linsen der Welt und macht sich die optische Qualität mit so einer Hinterhoflinse in einem Adapter kaputt. Dann lieber Crop. Link to post Share on other sites More sharing options...
steppenw0lf Posted August 4, 2016 Share #4 Posted August 4, 2016 Sieht interessant aus. Sowas sollte es für meine alten Rollei 6000 Objektive geben. Es gibt eine grosse Anzahl dieser Adapter für FF Objektive an APS-C Kameras. Die AF Geschwindigkeit soll grässlich sein und die optischen Resultate eher schlecht (ok bei manchen Objektiven, ganz schlecht bei anderen, aber nie wirklich gut). Die bisherigen Adapter werden daher eher als Spielzeug betrachtet. Adapter ohne Glas wären daher wohl optisch besser (auch wenn sie bei Weitwinkel nicht helfen). (Was würde wohl passieren, wenn man die Linse herausbricht ?) Link to post Share on other sites More sharing options...
poseidon Posted August 4, 2016 Share #5 Posted August 4, 2016 Sieht interessant aus. Sowas sollte es für meine alten Rollei 6000 Objektive geben. Es gibt eine grosse Anzahl dieser Adapter für FF Objektive an APS-C Kameras. Die AF Geschwindigkeit soll grässlich sein und die optischen Resultate eher schlecht (ok bei manchen Objektiven, ganz schlecht bei anderen, aber nie wirklich gut). Die bisherigen Adapter werden daher eher als Spielzeug betrachtet. Adapter ohne Glas wären daher wohl optisch besser (auch wenn sie bei Weitwinkel nicht helfen). (Was würde wohl passieren, wenn man die Linse herausbricht ?) Hi, dann geht nichts mehr auf unendlich, oder ggf. auch gar nichts, oder nur extrem Nahbereich. Denke ich mal.............. Gruß Horst Link to post Share on other sites More sharing options...
